2000 b16 swap into 96 civic
Old Sep 2, 2007 | 06:32 PM
tigueremalo's Avatar
Default 2000 b16 swap into 96 civic
i have a 2000 b16 with complete wire hardness that i want to swap into my 96 dx coupe will the hardness fit plug n play with my civic????
Old Sep 2, 2007 | 06:37 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: 2000 b16 swap into 96 civic (tigueremalo)
You have to get b-series mounts. Use the b-series harness and ecu, but yes, as far as swapping engines go all b-series are pretty plug and play.
Old Sep 2, 2007 | 07:19 PM
Default Re: 2000 b16 swap into 96 civic (ek forever guy)
what about the plug under the hood on the driver side???
Old Sep 2, 2007 | 07:26 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote">what about the plug under the hood on the driver side???</TD></TR></TABLE>
There's at least a dozen of those.
Old Sep 2, 2007 | 07:33 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote"> will the hardness fit </TD></TR></TABLE>
lol...
anyway, moved into hybrid because there is a wealth of info in there and lots of people who are in the same boat as you
Old Sep 3, 2007 | 12:53 AM
the one the wire hardness plugs at on the driver side
Old Sep 3, 2007 | 06:57 AM
builthatch's Avatar
MiG-21 superfan
nah, it's the fact that you are saying "hardness". that is funny to me.
it's harness ; )
Old Sep 3, 2007 | 09:21 AM
Default Re: 2000 b16 swap into 96 civic (builthatch)
jejeje u got me am like wats he talking about i always do it i dont know why
thanks though watch me stll do it though thats the funny part
Old Sep 3, 2007 | 04:11 PM
USDMCIVICHATCH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">You have to get b-series mounts. Use the b-series harness and ecu, but yes, as far as swapping engines go all b-series are pretty plug and play.</TD></TR></TABLE>
wrong, wrong and wrong
you can't use a 99-00 harness on 96-98, and you don't have to change your motor mounts just have to use the 99-00 Si brackets and you can't use the 99-00 Si computer on a 96-98 either
Old Sep 3, 2007 | 05:33 PM
Ek Forever y0!
Default Re: 2000 b16 swap into 96 civic (USDMCIVICHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">you can't use a 99-00 harness on 96-98, and you don't have to change your motor mounts just have to use the 99-00 Si brackets and you can't use the 99-00 Si computer on a 96-98 either</TD></TR></TABLE>
O RLY?
Please, elaborate. His new motor will have all the "99-00 sensors, thus he'll need the 99-00 harness, thus needing the 99-00 ecu.
No, you're right. He doesn't HAVE to use the mounts, but it would be easier to.
Again why can't he use a different ecu in his car? That makes no sense. My brothers originally obd2 96 integra is running an obd1 ecu and an obd1 motor and harness.
Old Sep 3, 2007 | 09:36 PM
because 96-98 are obd2a and 99-00 are obd2b. if you use a 99-00 harness on a 96-98 then you will have one less plug at the ecu. It just flat out doesn't work and this is from EXPERIENCE I'm not just pulling it out of my ***. Anyone that has done a few swaps knows this
Old Sep 4, 2007 | 04:32 AM
Ek Forever y0!
I've done two swaps thank you very much. Just use a jumper harness or swap the ecu's. We did this on a 97 dx with a 99 y8 swap. We used the 99-00 harness, and just plugged it into the 99-00 ecu for the first few weeks before we chipped a p30.
That's why you CHANGE the ecu, so the harness DOES plug in.
No, you can't just change the harness, it has to be for that motor and that ecu.
All the OP has to do is use the 99-00 b16a2 harness, plug it into the P2T.
it doesn't matter that the original motor was obd2a. The new on is obd2b, so the harness and ecu should be if you're retaining a stock ecu.
Besides, if you use an obd2a harness on an obd2b motor you're probably missing a few sensors and if you try to use the correct ecu for the motor then it will throw a cel.
Old Sep 4, 2007 | 07:25 AM
but i have the 99-00 si ecu for it so why wouldnt it plug n play
Old Sep 4, 2007 | 07:27 AM
you are just flat out wrong, and I already explained why and your not getting it....
Old Sep 4, 2007 | 10:09 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">you are just flat out wrong, and I already explained why and your not getting it....</TD></TR></TABLE>
No you weren't very clear.
The harness/ecu/engine are all interchangeable, so the fact that the motor is obd2a/b can be changed as well.
We put obd2b motors in obd1 and obd2a all the time. It's a matter of either a jumper harness, or using the right ecu. Either will work.
Old Sep 4, 2007 | 12:58 PM
yea I was bro,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">because 96-98 are obd2a and 99-00 are obd2b. if you use a 99-00 harness on a 96-98 then you will have one less plug at the ecu. It just flat out doesn't work and this is from EXPERIENCE I'm not just pulling it out of my ***. Anyone that has done a few swaps knows this</TD></TR></TABLE>
Old Sep 4, 2007 | 01:03 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote">but i have the 99-00 si ecu for it so why wouldnt it plug n play</TD></TR></TABLE>
It's 100% plug and play, use the b16a2 motor, obd2b harness, and p2t ecu. It will work.
Old Sep 4, 2007 | 01:04 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">if you use a 99-00 harness on a 96-98 then you will have one less plug at the ecu </TD></TR></TABLE>
On a 96-98 chassis?
he's putting a 00 motor, in his 96-98 chassis, if he uses the obd2b harness it will plug into the p2t obd2b ecu.
Old Sep 4, 2007 | 01:11 PM
ok let me explain further, 96-98's have three plugs coming through the firewall to the ecu and 99-00's have only two coming through the firewall and the third plug is part of the dash harness so if you use it on a 96-98 you'll be missing the third plug. And just so you guys know I do swaps for a living and have done so many I lost count. Also I have owned a bunch of 96-98 and 99-00 Ek's as well as Dc2's and Eg's and have done every motor from D's to k20's so I know my ****. I'm sorry if I came off like a hard *** I just wanna help this guy get the right stuff, just like you do. So if you guys don't believe do a search as this swap been covered a zillion times on here
Old Sep 4, 2007 | 01:17 PM
builthatch's Avatar
MiG-21 superfan
it has- that is why katman made this inquiry-
https://honda-tech.com/zerothread?id=2039193
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">ok let me explain further, 96-98's have three plugs coming through the firewall to the ecu and 99-00's have only two coming through the firewall and the third plug is part of the dash harness so if you use it on a 96-98 you'll be missing the third plug. </TD></TR></TABLE>
And how hard is that to change?
A simple jumper harness would solve the problem. Like with other obd issues.
Old Sep 4, 2007 | 01:21 PM
you would have to install a whole 99-00 dash and dash harness, but the easiest solution would be to get a 96-98 Ex engine harness and use that
Old Sep 4, 2007 | 01:23 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMCIVICHATCH &raquo;</TD></TR><TR><TD CLASS="quote">but the easiest solution would be to get a 96-98 Ex engine harness and use that</TD></TR></TABLE>
Correct. But when We did an obd2 b18b1 swap into a 99 civic we just got a jumper harness and it solved all but the o2 sensor issue. That's what I was implying, I figured it was a given.
Old Sep 4, 2007 | 04:31 PM
Q:when swaping engines out of 96-98 / 99-00 civics i leave the harness on the motor so it has to come out the cars cabin correct?
A:Correct
Q:so that means in order for the harness to come out the ecu has to be unplugged correct?
A:correct
now i dont remember if the dash harness plugs in to the ecu because i didnt take the ecu out but.....
Q:then if thats the case a 99-00 si dash harness will make the swap plug n play correct?
A:correct
Old Sep 4, 2007 | 07:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tigueremalo &raquo;</TD></TR><TR><TD CLASS="quote">Q:when swaping engines out of 96-98 / 99-00 civics i leave the harness on the motor so it has to come out the cars cabin correct?
A:Correct
A:correct
A:correct</TD></TR></TABLE>
yes you are correct, except that on 96-98's all three plugs are coming from the engine harness so you won't have a plug from the dash harness on your car, but on 99-00 the engine harness has only two plugs coming to the ecu and the third is in the dash harness. so ya if you used the 99-00 dash harness it would work, but getting a 96-98 Ex engine harness and putting that on the b16 would be a whole lot easier.
