0BD0--->OBD1
Old Sep 2, 2007 | 05:02 PM
nitewolf's Avatar
Default 0BD0--->OBD1
i have a 91 DX hatch with the orig. underdash i have a DA obd1 swap i left he engine harness on it. i want to jux convert mi plugs so i can do obd1 swaps easily (plug and play) i jux want to start a fresh write up on how to do it.
thanks in advance
Old Sep 2, 2007 | 07:41 PM
4twenty_CRX's Avatar
Default Re: 0BD0--->OBD1 (nitewolf)
If you're asking what you need to convert from OBD0 to OBD1...
[ OBD1 ECU ]
[ OBD0-OBD1 CONVERSION HARNESS ]
[ OBD1 INJECTORS ]
[ OBD1 DISTRIBUTOR ]**
[ OBD1 4-WIRE O2 SENSOR ]
lose the resistor box and splice the wires together and you're good to go.
there's writeups all over this site just hit "search"
**I used my original OBD0 wiring harness so I had to cut off the OBD1 connectors and solder on my OBD0 ones so it can plug up nicely.
Old Sep 2, 2007 | 09:44 PM
dem0nk1d's Avatar
you can run the obd0 injectors as long as you have the resistor box. but nobody cares.
i think he is saying he would like to do a full write up on his obd0 to obd1 project.
Old Sep 3, 2007 | 06:36 AM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitewolf &raquo;</TD></TR><TR><TD CLASS="quote">i have a 91 DX hatch with the orig. underdash i have a DA obd1 swap i left he engine harness on it. i want to jux convert mi plugs so i can do obd1 swaps easily (plug and play) i jux want to start a fresh write up on how to do it.
thanks in advance</TD></TR></TABLE>
so is this just a hacked up question or a statement? "jux" really, you call that a word?
Old Sep 3, 2007 | 07:03 AM
vw eater's Avatar
hope this helps
dc5itracer
10
Mar 26, 2011 10:29 AM
Dkahn18
Feb 18, 2009 04:41 PM
projsectEF
Jul 25, 2006 12:32 AM
jdmtim
Oct 5, 2004 07:46 AM
h46it
Jun 18, 2002 05:23 PM
