typeR in a crx ??
Old Jun 14, 2002 | 10:06 PM
.ShawnD.'s Avatar
Default typeR in a crx ??
say you already have a b16a and all the wiring .. what has to be done to the motor mounts?? or do they make some that work now?? im just courious and wonder what it would take to put a b18c5 in the crix?? any info would help thanks!!
Old Jun 14, 2002 | 10:20 PM
No More Civic's Avatar
Default Re: typeR in a crx ?? (.:s h a w n D:.)
Yes, they make bolt in mounts go to http://www.hasport.com/ for them. And there's someone in this forum that has a b18c5 in his EF, I'm not sure of his name though. You might want to just do a search for it.
Old Jun 14, 2002 | 10:27 PM
.ShawnD.'s Avatar
Default Re: typeR in a crx ?? (SlowCivicDX)
well i can probably get the motor really cheep im not sure what all comes with it but im just trying to get some ideas on what it takes cuz i could probably buy the motor and then sell the b16 and use the money for mods and what not
Old Jun 15, 2002 | 12:53 AM
88crxoncrack's Avatar
i'm pretty sure you can use your mounts and just shim down the motor with some washers on the side mounts. only difference is deck height by a very small amount
Old Jun 15, 2002 | 02:57 AM
Radex's Avatar
I have B18C6 in my CRX, but this is EE8. Need any help, just mail me!
Old Jun 15, 2002 | 04:56 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
If you already have a B16 in your EF, you don't need to change the mounts.
Use all the brackets on your B16 and transfer them to the 1.8
I did that, and all I had to change was the Thermoswitch wiring since the B18C5 has it at the thermostat housing, while the B16 has it at the back of the block.
You can use the US hood, but you will need to remove the underhood support
right over the valve cover.
Good luck, you will love the 1.8 on your CRX.
Old Jun 15, 2002 | 09:52 AM
.ShawnD.'s Avatar
Default Re: typeR in a crx ?? (Spaceballs the lunch box)
what all did you have to do as far as the ecu,axles, and tranny cuz its hydro and i have the cable one?? anything different then what i have now besides the tranny cuz if its just a direct bolt in then shoot it wont take me long before its in my car .. what about daily driver.. does it get on your nerves?
let me make sure i clear somthings up so i dont confuse people
ok i have right now in my car
89 crx SI
b16a
y1 tranny
teg axles
sir hood
place racing mounts
place racing harrnest
dc headers
thermal exhaust
and a few other things but not motor related??
i hope this helps??
[Modified by .:s h a w n D:., 6:56 PM 6/15/2002]
Old Jun 15, 2002 | 10:02 AM
spettinger's Avatar
i would try to run the C5 trans, there was a guy on here that had made a bracket that turns the clutch cable sideways and makes it act like a slave cylinder. you could run your B16 trans as well.
Old Jun 15, 2002 | 10:15 AM
.ShawnD.'s Avatar
Default Re: typeR in a crx ?? (wreckedhatch)
so pretty much i need everything but the tranny,mounts, axles? what about the wiring and the ecu? anything need to be cut and spliced on the wiring besides the thermostat?
Old Jun 15, 2002 | 01:41 PM
.ShawnD.'s Avatar
ttt
Old Jun 15, 2002 | 03:43 PM
JDM_DOHC_SiR's Avatar
New User
if you have the wiring already then you'll just have to worry about the hood clearance... 7mm worth
Old Jun 15, 2002 | 07:08 PM
The_Brian's Avatar
Default Re: typeR in a crx ?? (JDM_DOHC_SiR)
wiring? just use the b16 distributor... its white plug and the type R should be grey plug.... uhmmm hood clearence? is the type R anything like a b20 VTEC cause a freind of mine toke out his b16 and installed a b20 and still used the place racing mounts he had for the b16 mounts in fine and hood shuts.... as far as the tranny goes... try to use the R tranny due to the fact its LSD... if you have a LSD s1 or y1 use that... simple and you can still sell the R tranny to someone
Old Jun 16, 2002 | 05:44 AM
.ShawnD.'s Avatar
Default Re: typeR in a crx ?? (JDMinPorterville)
what about the ecu?
Old Jun 16, 2002 | 06:09 AM
tunedcivic's Avatar
the type r has a different wiring all together like the gsr i thought. so if i have a b16 in my car...the type r will plug and play? what?
Old Jun 16, 2002 | 02:02 PM
JDMBOLONI's Avatar
Default Re: typeR in a crx ?? (tunedcivic)
the easiest way to put a B18C5 in your car is to use all the OBD-0 sensors that are different duh! use the B16A1 distrubutor, D16A6 or B16A1 injectors, obd-0 coolent sensor and then you don't have to do any wiring other then VTEC. my sugestion is to get a PR3 chipped that dosn't use the knock sensor, governor and secondary O2. thats what i am going to put in soon and I think it should work fine!
Old Jun 16, 2002 | 02:05 PM
E-lude78's Avatar
just get a Type R longblock and transfer all your sensors, fuel injectors etc from the B16A.
the_rex
Jan 30, 2008 04:33 PM
gtturborex
Sep 6, 2005 09:59 AM
99sonicbluegsr
Mar 7, 2004 02:05 PM
dcviperboy
Sep 23, 2003 08:18 AM
