Just installed JDM 4-1 and carsound cat....
Old Jun 14, 2002 | 08:49 PM
Ferrell's Avatar
Default Just installed JDM 4-1 and carsound cat....
and now my exhuast is rattling, i noticed that my muffler is about 1/4 inch out further than before. I had to push out on my catback to get the cat between the header and the be pipe. It only rattles at idle and rpms. Im assuming the catback is rubbing against the metal parts of underneath the car, what can i do? get underneath and jiggle around and try to get them to seat in the rubber hanger? or take it to a shop and have them look at it?
JDM 4-1, carsound cat, Apexi N1
TIA
Old Jun 14, 2002 | 09:34 PM
TakaIntegra's Avatar
Default Re: Just installed JDM 4-1 and carsound cat.... (Yes it's VTEC)
DId you remove the heat shield above the cat?
Old Jun 15, 2002 | 02:27 AM
shirubia's Avatar
Default Re: Just installed JDM 4-1 and carsound cat.... (TakaIntegra)
yeah.
Old Jun 15, 2002 | 04:50 AM
StyleTEG's Avatar
Default Re: Just installed JDM 4-1 and carsound cat.... (shirubia)
I had the same problem when I installed some POS DC 4-2-1, seams the header pushed the whole system back about an inch and a half, enough where the pipes were rattling against the heatsheilds.
I took it to a muffler shop and had them cut out a small section of the A pipe, and weld it back together.
Old Jun 15, 2002 | 04:51 AM
AW's Avatar
AW
I assume you have a GSR? The JDM headers, stock and aftermarket are longer than the regular GSR header and cat combinations. When I put my Mugen header and cat on I had to have my GSR Greddy PE exhaust shortened or it would not fit properly. You may have the same problem...
Old Jun 15, 2002 | 11:12 AM
shirubia's Avatar
Default Re: Just installed JDM 4-1 and carsound cat.... (AW)
although its my o2 sensor thats hitting the shift linkage, someone suggeted bending the hangers on the exhaust piping, I have an apexi exhaust too.
Old Jun 15, 2002 | 12:10 PM
eh-D's Avatar
Don't bend anything, go to a mufflershop and let them cut a small section out of the B-pipe and everything will fit like stock. I'd guess that you'd be out no more than 20 bucks.
ComCool
Nov 21, 2007 08:32 PM
pistol
Nov 26, 2002 11:26 AM
akhom
Aug 2, 2002 08:58 AM
Ferrell
Jun 15, 2002 05:06 AM
12 oz.
May 28, 2002 11:48 AM
