Probe rods
Old Sep 2, 2007 | 07:48 AM
supratin's Avatar
Default Probe rods
Anyone ever used probe i beams rods in a all motor build? Im building a ls crank gsr block since i have to buy the ls rods use arp bolt resize them I figure ill just go aftermarket but dont want to use h beams. Shooting for 230 to 250 whp.
Old Sep 2, 2007 | 09:00 AM
NJIN BUILDR's Avatar
Default Re: Probe rods (supratin)
I don't have any direct experience with the probe rods.With that said I would stay with the proven Carrillo,Crower,Eagle,or Scat rods.I'm not sure why you don't want the h beam rods .My guess is the weight and if that's the case than the Carrillo a beam would be the choice.And remember if you plan to run an oem piston they would need to be modified (clips) to use an aftermarket rod.
Old Sep 2, 2007 | 09:19 AM
supratin's Avatar
Default Re: Probe rods (NJIN BUILDR)
Carillo a beams are nice but expensive the weight is the reason i dont want to run h beams if i did i would use eagle. Maybe ill use stock ls rods resized with arps and balanced they list two different sizes 8mm and 9. But the 9s are listed for b18c and b16 will they work with the ls rods?
Old Sep 2, 2007 | 09:30 AM
The 8mm and the 9mm are different lengths also.You will need to use the 8mm ones.I'm guessing you will need to turn over 8500 to get the hp you looking for.I wouldn't recommend the ls rods for those rpm's.
Old Sep 2, 2007 | 09:38 AM
Chris Tune's Avatar
good stock ls rods with arps are good enough for 9k. as long as oil clearance are good.
Old Sep 2, 2007 | 09:59 AM
supratin's Avatar
Default Re: Probe rods (Chris Tune)
I cracked two valve guides so im doing a build now. S2s2 cams, eventually pro 2s, edelbrock victor x, gsr block, ls crank i would rather over build the bottom end then not enough looks like eagles or manleys on cast pistons thanks for all the advice.
kenizzle
Feb 14, 2012 02:14 PM
liquidrider
Dec 7, 2009 04:07 AM
b16bhatch
Oct 5, 2006 04:17 AM
EGcivicvtec
Jan 23, 2006 03:24 PM
