Front rotors on a 1997 Honda Accord LX
Old Sep 2, 2007 | 07:45 AM
doc03sports's Avatar
Default Front rotors on a 1997 Honda Accord LX
How do you change the front rotors on a 1997 Honda Accord LX?
Old Sep 2, 2007 | 07:52 AM
honda_kid42's Avatar
Default Re: Front rotors on a 1997 Honda Accord LX (doc03sports)
took me 2 seconds to find this!!!!
SEARCH!!!!
https://honda-tech.com/zerothread?id=1281812
Old Sep 2, 2007 | 10:14 AM
Default Re: Front rotors on a 1997 Honda Accord LX (honda_kid42)
Thanks honda-kid42, but do you know if the hub nuts are right hand or left hand thread. We can`t get the hub nut to break loose. We`ve busted 2 rachets and a breaker bar already.
Old Sep 2, 2007 | 10:42 AM
not too sure on that....i have actually never done it myself....
Old Sep 2, 2007 | 04:10 PM
The-Kid's Avatar
regular. So lefty loosey. righty tighty.
Did you unstack that little dent on the nut. Follow the instructions from <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_kid42 &raquo;</TD></TR><TR><TD CLASS="quote">took me 2 seconds to find this!!!!
SEARCH!!!!
https://honda-tech.com/zerothread?id=1281812</TD></TR></TABLE>
That helped me. Use some PB blaster if it's too hard. And I suggest renting an air gun or any impact gun. Short burst should help you. My car broke a breaker bar....
Old Sep 2, 2007 | 04:47 PM
Default Re: Front rotors on a 1997 Honda Accord LX (The-Kid)
Yes we took the dent out of the nut, but it still won`t break loose.
Old Sep 2, 2007 | 08:06 PM
The-Kid's Avatar
Air impact wrench. Short burst. Keep doing that for like 10 times, it'll come loose. Soak it with some PB blaster.
Old Sep 4, 2007 | 04:21 PM
TouringAccord's Avatar
H-T Order of Merit
haha, you talking about the axle nut?
if so, I remember breaking a couple 1/2" drive ratchets and and 1/2" drive breaker bar. I was using the handle from my aluminum jack and finally got a steel pipe and was finally able to break it free. I think the aluminum pipe was flexing too much and wasn't getting that torque to the ratchet like I should have been. Either way, using a 1/2" drive breaker bar and a steel cheater pipe has worked great, since then, for breaking axle nuts free.
Old Sep 4, 2007 | 04:42 PM
lowered94accord's Avatar
Default Re: Front rotors on a 1997 Honda Accord LX (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote"> Either way, using a 1/2" drive breaker bar and a steel cheater pipe has worked great, since then, for breaking axle nuts free.</TD></TR></TABLE>
X2...they have always come loose easy for me...just spray it down with a little PB blaster and let is soak in the bust out the breaker bar and cheater pipe! bingo
Old Sep 4, 2007 | 08:48 PM
kidcool1977's Avatar
SHAME ON YOU REBECCA!
Community Builder
Default Re: Front rotors on a 1997 Honda Accord LX (lowered94accord)
ok,
am replacing my wheel bearings on my 94 accord, problem is the two out of four bolts that are in the back of the steering knuckle were broken, so i went to take off the remaining two, one broke off the other one came off, but the hub plus bearing did not come off and the rotor is loose but i can't remove it, someone have any ideas on what to do.
Old Sep 4, 2007 | 09:10 PM
The-Kid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lowered94accord &raquo;</TD></TR><TR><TD CLASS="quote">
X2...they have always come loose easy for me...just spray it down with a little PB blaster and let is soak in the bust out the breaker bar and cheater pipe! bingo</TD></TR></TABLE>
Man you guys are lucky. The thing broke my breaker bar...
As for this <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidcool1977 &raquo;</TD></TR><TR><TD CLASS="quote">ok,
am replacing my wheel bearings on my 94 accord, problem is the two out of four bolts that are in the back of the steering knuckle were broken, so i went to take off the remaining two, one broke off the other one came off, but the hub plus bearing did not come off and the rotor is loose but i can't remove it, someone have any ideas on what to do.</TD></TR></TABLE>
I had some trouble seperating the wheel bearing/hub from the knuckle. Since you are replacing the bearing, hammer it out with all your might. Use the axle nut socket to help you push it out. I know a sledge hammer will do the trick. Worst come to worst, you can either....
-get a hub and bearing pre-assembled
-or press it out.
Old Sep 4, 2007 | 09:47 PM
Community Builder
well, the knuckle is out, basically knuckle/hub/rotor/bearing all in one big piece, like i said in my OP all three nuts broke and the rotor spins but nothing is seperating, anyway i haven't had a chance to get to it cause by the time everyhing was off the car it got dark, so i'll think of something, and try the sledge hammer and i'll search, but if anyone has inputs please post. thanks
I forgot if i use a sledge hammer i'll destroy my rotor so it will not work.
Old Sep 5, 2007 | 03:15 AM
H-T Order of Merit
Default Re: Front rotors on a 1997 Honda Accord LX (kidcool1977)
you dont need to hit the rotor, just hit the bearing from the back side of the knuckle. This should help drive it out unless it's rusted in there REALLY good. Mine were when I replaced my rotors so I had to have them separated at a shop with a press. This isn't always required but in extreme cases it sometimes is.
qhiggy
Jan 28, 2014 09:46 AM
95accord327
Aug 4, 2012 05:51 PM
ANGEL4PEACE777
Aug 14, 2007 03:45 AM
whitelightning
May 6, 2004 06:29 AM
dchi_t
Mar 7, 2003 03:21 AM
