SWAP Axel Question!! PLS HELP IF YOU CAN!!
Hey all, i was curious...I started doing my swap in my EF and everything was going smooth except for a few things i kind of got over, but my big concern is my axles...I had a set on my b16a, granted i dont know what axles they are to begin with, they were given to me, and now i wanted to use them on my GSR swap. Thing is, i have the b18c, and a cable b16a trans. I am using the b16 intermediate shaft, and b16 trans, but the axles dont line into the control arms...they are too long. I then was told that the GSR's have a wider block then the b16, so thats why they extend past the control arms. so now i was wondering what axles i have to get in order to make this work???? I've never seen or heard of this happening, but i was told by two other people to go and get 90-91 integra LS axles because thos would work...is this true or does someone have the correct answer to my problem?? Thanks for any help I get!!!
If you have b16 axles yes you can use them, you can use the b16 intermediate shaft as well, but if you are using the shaft on the gsr tranny then make sure you use a 90-91 integra oil seal on the side of the tranny that the shaft goes in
