new swap in.car wont start
Old Sep 1, 2007 | 10:07 PM
krazyhmongboi's Avatar
Default new swap in.car wont start
so i finallie finished puting the ls motor in..i think my battery is bad also but with a walbro fuel pump or any after market fuel pump your suppose to hear it prime up right? maybe its been sitting too long?..when i put it to the second click it doesnt sound like it did before the swap..wil letting the car sit for too long(2 months in this case) make the fuel pump not work animore?
Old Sep 1, 2007 | 10:41 PM
92VXeg's Avatar
check the relay
Old Sep 2, 2007 | 12:10 AM
what do i look for? its in the fuse box?(under hood)
Old Sep 2, 2007 | 12:11 AM
_Spugen_'s Avatar
Under the dash...its a little rectangular box held on with a 10mm bolt.
Old Sep 2, 2007 | 12:16 AM
alright will do that inthe morning..but after i take it out..is it gonna b obvious that something is wrong with it or what should i look for?
Old Sep 2, 2007 | 07:37 AM
bunnyhatch93's Avatar
Default Re: new swap in.car wont start (krazyhmongboi)
Sometimes kicking/hitting the main relay will make it work. Quick question, when u turn the key too the second position does the engine light turn off? If it does not that is a good sigh that the main relay is not working. Also are all of ur grounds connected too the motor, ie valve cover, water neck housing, transmission etc.
Old Sep 2, 2007 | 07:39 AM
i got it working! sigh..but sigh of relief.. thanks guys for the help
theofficialrj
21
Apr 12, 2015 07:48 PM
91' LS-VTEC
15
Jun 7, 2009 01:51 PM
miguel329
Jan 5, 2009 06:36 PM
fryman
16
Dec 31, 2008 07:56 AM
Soccerking3000
12
Dec 21, 2005 06:10 PM
