Valve lash/adjustment problem
Old Sep 1, 2007 | 06:26 PM
jackmode9316's Avatar
* B A N N E D *
Default Valve lash/adjustment problem
I have a problem when adjusting my valve clearance. Basically I got the intake valves low enough to where the feeler guage barely grabs. But after and before I tighten the lock nut up, the rocker arm is loose. I can wiggle it and even hear the play in it when I jiggle it. I also made sure to have the crankshaft set on the TDC mark and i was working off of cylinder 1.Could this mean bent valves? Its a jdm d15b. What could this be, the other valves don't have that much play. Any help appreciated. Thanks in advance
raverx3m
Dec 10, 2013 01:50 PM
white_n_slow
May 15, 2005 07:51 PM
steve_meyer
Oct 15, 2004 06:00 AM
sneakychaos
Sep 9, 2002 05:48 PM
BreakStuff
Nov 29, 2001 06:54 PM
