d16y8 motor problem
i went from the d16y7 to the d16y8 and im still using my dizzi from the first motor an computer will t hat cause any problems or cause the idle to bounc. its a holiday weekend an no one in my area has the v-tech dizzi until tuesday will i cause an damage to my motor runnin the original dizzi an computer.
p.s i do havethe new p28 computer also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundpsych »</TD></TR><TR><TD CLASS="quote">No your not going to cause any problems just no vtec and i think a cel until you get that Dizzy swapped out.</TD></TR></TABLE>
Actually that is wrong. It depends on if you have a 3 wire setup Y8 or a 2 Wire Y8 from a standard. If you have the 2 wire that is why your idle bounces.
iacv- gotta do this- http://www.ff-squad.com/tech/w...8.jpg, toward the middle/ bottom of that document.
distributors are the same between y7 and y8.
and wtf is up with that poll? someone answer quickly before i issue a ban....
Crazyplum808EG9
Sep 14, 2016 01:17 AM
Devilry
Nov 19, 2005 09:39 AM
