Holiday Weekend Cleanout!!! brake stuff, ecu's, misc...
Old Sep 1, 2007 | 02:17 PM
UberMunkey's Avatar
Default Holiday Weekend Cleanout!!! brake stuff, ecu's, misc...
all this is located in central MA, willing to travel to meet up for the larger stuff as long as it's not hours away. smaller stuff you can come get.
1" master cylinder - $50
-- from 98+ Integra RS, should be a direct bolt on for ek's, no bending or flaring lines. comes with reservoir.
(2) 40/40 proportioning valves - $40 ea.
-- off EK civics, you should be using this if your ek has a rear disc swap, some came with them but not all.
Civic HF exhaust manifold - SOLD
-- this + an adapter plate = cheap, durable turbo manifold. should fit all d-series 88-00.
virgin PR4 ECU - $70
-- OBD1 b-series non-vtec manual transmission ecu.
virgin P06 ECU - $70
-- OBD1 d-series non-vtec manual transmission ecu.
EK civic ex exhaust manifold - $25
-- use this if you want to remove your mani/converter assembly in your ek for whatever reason. should bolt up to all d-series ek's.
rear integra disc brake swap - $150
-- off a dc integra, so should fit all eg's and ek's. NO lines or cables are included.
front ex/si brake swap - $150
-- use these if you are going to do a front brake swap on your ek. the integra knuckles alter suspension geometry, and these have the same size rotors as dc integras anyway. NO lines included.
Buy both the front and rear brake swaps for only $250!
can get pics if you really need them, but everything is in good shape, and i think we all know what this stuff looks like
pm or reply with any questions. have a great labor day weekend!
Modified by UberMunkey at 6:20 PM 9/4/2007
Modified by UberMunkey at 10:05 PM 9/7/2007
Old Sep 2, 2007 | 04:09 PM
UberMunkey's Avatar
up up up
Old Sep 4, 2007 | 12:50 PM
UberMunkey's Avatar
ttt
pics coming tonight (hopefully)
Old Sep 4, 2007 | 05:23 PM
UberMunkey's Avatar
Default Re: Holiday Weekend Cleanout!!! brake stuff, ecu's, misc... (UberMunkey)
bumped up with pics!
Old Sep 6, 2007 | 05:40 AM
UberMunkey's Avatar
uppppp
Old Sep 7, 2007 | 06:05 PM
UberMunkey's Avatar
hf mani sold
Old Sep 9, 2007 | 06:57 AM
UberMunkey's Avatar
ttt
riggs_rz
May 30, 2013 01:01 AM
Bone Stock
Dec 4, 2005 02:19 PM
hialeahzbg
Sep 21, 2005 05:16 PM
Stroker
Mar 16, 2003 10:36 PM
