problem with d16y7
Old Sep 1, 2007 | 12:47 PM
civicEXtreme's Avatar
Default problem with d16y7
First off, I just dropped this engine in the car cause the last one shot a rod through the block. In the process of turboing this engine and they engine has never really ran non-turbo but the car has yet to see boost.
ok... cly 2 will not fire worth a damn at all, I switched plugs, didn't switch wires yet, and pretty sure it wouldn't be a vac leak. Also, when I had my chipped ecu connected to the car the car refused to go over 4k, with my stock ecu the car would rev like normal.... any ideas?
Also, the car isn't yet to see boost cause I don't want it to, it just refuses to boost.
Old Sep 1, 2007 | 01:04 PM
hondamark35's Avatar
Default Re: problem with d16y7 (civicEXtreme)
you need to check the compression and the injector on that cylinder. those can go bad as well
Old Sep 1, 2007 | 01:10 PM
Default Re: problem with d16y7 (hondamark35)
well... its got dsm injectors, I'll check them asap.
Also, never really understood how to check compression, how do I do that? And if I checked compression, what would this tell me and how would I fix it?
Old Sep 1, 2007 | 02:53 PM
boostedmax
Nov 4, 2009 10:29 AM
ls_turbo_#97
Oct 19, 2009 02:28 PM
a1320honda
Jul 2, 2009 03:33 AM
j-bird20
Nov 26, 2006 02:16 PM
VTgringo
Aug 18, 2003 02:11 PM
