possible steering problem
Old Sep 1, 2007 | 11:23 AM
ohnoitsryan's Avatar
Default possible steering problem
car: 00 civic dx - lowered about an inch with 00 civic si rims
so lately i have noticed that when im turning the wheel it feels like its rubbing on something, and i can hear this squeaking/rubbing sound. it does it when i turn the wheel left or right and it's constant.
i do have power steering and i checked the fluid and everything seems to be in order.
anyone have any idea?
Old Sep 1, 2007 | 12:35 PM
Late Riser's Avatar
Default Re: possible steering problem (ohnoitsryan)
Have you checked to see if there is anything physically touching the tire or wheel when you turn? Another thing to check is your tie rods, make sure they are in good shape. Check under the dash make sure ther is nothing touching the steering column that shouldnt be.
Old Sep 1, 2007 | 12:42 PM
r d x's Avatar
1st. Whats the tire size? Going from 205 to 195 may help a bunch.
2nd. You have camber, but I am pretty low. I corrected my hardcore rub...rubb...rubb...ruuuuuuubb on u turns by getting a camber kit.
However, i got nipples on the shock tower by camber kit impact.
Old Sep 1, 2007 | 02:00 PM
I have had these rims with 205 tires for months and this just started happening.
Nothing is rubbing where the wheel is at either.
Hm.
Old Sep 1, 2007 | 05:19 PM
bump
90tegturbo
Mar 5, 2008 01:51 PM
216.226.142.95:27016
Suspension & Brakes
Dec 29, 2006 09:07 AM
ultimatehonda
Jul 8, 2003 03:28 AM
Dangydang
Dec 29, 2002 06:40 PM
MattD@Stoptech
13
Aug 15, 2002 10:42 AM
