What is the max rpm everyone is revving ls rods with arp bolts?
Old Sep 1, 2007 | 11:06 AM
HAMOTORSPORTS's Avatar
Default What is the max rpm everyone is revving ls rods with arp bolts?
Old Sep 1, 2007 | 11:09 AM
UNKNOWN_MEMBER's Avatar
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (HAMOTORSPORTSUSA)
i took mine to 9k all the time
Old Sep 1, 2007 | 11:41 AM
Mike@K-Tuned's Avatar
Mine have seen a 9200 rpm rev limit numerous times at the track.
Old Sep 1, 2007 | 12:23 PM
wow. I must be underestimating these oem rods
Any body think we'll have trouble with these holding up to a set of pro2's with 12.0:1 compression?
Old Sep 1, 2007 | 12:41 PM
No problem there. Sounds like your build is similar to a user on here named D-Rob. Check out some of his posts.
Old Sep 1, 2007 | 12:44 PM
itgsr98's Avatar
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (LSvtecMike)
8500 on my ls. dyno it and see where it stops making power. no point in reving the **** out of it if there nothing to be had.
Old Sep 1, 2007 | 05:15 PM
mx621's Avatar
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (itgsr98)
my rev limiter is @ 9k, nock on wood
Old Sep 1, 2007 | 08:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgsr98 &raquo;</TD></TR><TR><TD CLASS="quote">8500 on my ls. dyno it and see where it stops making power. no point in reving the **** out of it if there nothing to be had.</TD></TR></TABLE>
Don't worry, I know where these cams make their power as we have done several builds with them, but those were all using aftermarket rods. I just need around 9.1-9.2k of rpm available and want to see what kind of abuse people have been getting away with using ls rods.
So everyone vouches that they'll hold up?
Old Sep 1, 2007 | 08:31 PM
oldskool teggy's Avatar
look up user backdraft.. he was running them to 9500 all day long.. 11.96 @ 112 in the 1/4 mile
oem build 1.8
Old Sep 2, 2007 | 01:47 PM
Jdmb16sir2's Avatar
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (oldskool teggy)
i reved my old setup to 9200 and it was fine for 2 years . it usaully not the rod itself that gives up its the bearing or rod bolts can stretch if there oem.
Old Sep 2, 2007 | 02:08 PM
A1's Avatar
A1
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (Jdmb16sir2)
9600 on a raceday
Old Sep 3, 2007 | 09:37 AM
smileycvc's Avatar
Default Re: What is the max rpm everyone is revving ls rods with arp bolts? (A1)
with rod bolts you should be fine.
Old Sep 3, 2007 | 09:47 AM
nater_1's Avatar
would not hurt to have them shotpeened if you can.
Old Sep 3, 2007 | 04:30 PM
Combustion Contraption's Avatar
Honda Racing uses stock LS rods with ARP rod bolts in their 2.4l V8's , they take them to 19k ALL DAY with no problems! Just make sure you have a good tuner, and youll be ok!
&lt;CROME&gt;
Old Sep 3, 2007 | 05:42 PM
smileycvc's Avatar
Default Re: (nater_1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nater_1 &raquo;</TD></TR><TR><TD CLASS="quote">would not hurt to have them shotpeened if you can. </TD></TR></TABLE>
I believe LS rods are shotpeened from the factory
Old Sep 4, 2007 | 07:31 AM
Default Re: (Combustion Contraption)
tuning is not an issue as we tune here at the shop
Thanks for all your input everyone. I will keep you guys posted on how it turns out.
Old Sep 4, 2007 | 09:07 AM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itgsr98 &raquo;</TD></TR><TR><TD CLASS="quote">8500 on my ls. dyno it and see where it stops making power. no point in reving the **** out of it if there nothing to be had.</TD></TR></TABLE> Same here
Old Sep 4, 2007 | 09:17 AM
Jay_Sensing's Avatar
9400 at the track. Car has a couple of hundred all motor passes on it and about 15 on the bottle. No issues at all and I DD the car as long as it's not raining.
Old Sep 4, 2007 | 03:02 PM
projectef's Avatar
what about a stock lsv w/bolt ons and arp rod bolts. is 8500 good or 9k will be fine
Old Sep 4, 2007 | 03:22 PM
cartune network's Avatar
Default Re: (projectef)
to projectef:
just dyno it and see where u powerband drops out. if u dont make any power above 8500 than dont rev above 8500. its a simple as that. everyone here is saying that they hold up to 9+ so i dont think u would have a problem. DYNO it and see where ur making ur power.
SManiaci24
Dec 28, 2006 04:11 AM
imskatencrzy
Sep 30, 2006 07:12 PM
Flexin5
Mar 1, 2006 07:54 PM
93SIBLT4NOS
Mar 16, 2004 04:24 AM
stretracr
Jul 10, 2001 06:21 AM
