1992 Civic Sedan Power Windows Will Not Work
Old Sep 1, 2007 | 09:49 AM
tmitbyh's Avatar
Default 1992 Civic Sedan Power Windows Will Not Work
I am working on a 1992 Civic sedan with power windows. When I got the car the windows would not work. Typically I have seen this be the main window switch on the driver's side being bad. I purchased a new window switch and I still have nothing. I am not able to roll the windows down from the master switch, I am not able to roll the windows down from any of the door either.
Has anyone run into this problem before? Does anyone have ideas on what it could be other than the obvious and general answer of it being a wiring issue?
Old Sep 1, 2007 | 04:05 PM
hatchi's Avatar
Default Re: 1992 Civic Sedan Power Windows Will Not Work (tmitbyh)
did you check all the fuses??
Old Sep 3, 2007 | 08:02 AM
tmitbyh's Avatar
Default Re: 1992 Civic Sedan Power Windows Will Not Work (hatchi)
All four fuses for the power windows are good in the car.
Old Sep 4, 2007 | 01:53 PM
tmitbyh's Avatar
Any other suggestions or ideas?
Edward Mckenzie
Nov 23, 2013 01:26 PM
honda_civic1993
Nov 25, 2012 10:46 AM
VtecCivic93
May 5, 2008 03:47 PM
jdmkid8383
Jan 15, 2007 07:47 PM
