weird starting problem- searched well, need troubleshooters
ef w/b16a s1 tranny searched for about a week now
starter has been rebuilt and tested.
when i crank it, it spins freely. i could probably sit there and let it spin till the battery died or the starter goes bad. starter is on the tranny right, connected, grounds are fine.
i'm about certain that spark, compression, fuel and timing are fine. do they even matter if nothings moving beyond my flywheel?
it was suggested to push the car in a gear to turn the flywheel incase it had some broken teeth, well that doesn't seem to work either.
any ideals?
thanks in advance
any ideals?
thanks in advance
so the starter is not engaging the flywheel?
hmm..i'm no expert on this one,but i would think you have the wrong model of starter..unless the gear is supposed to move to the flywheel.
i dunno,sorry bro..i'll do a little research then try back for ya if you like?
had someone more experienced than me take a look at it today. evidently the flywheel is turning because the alt. belt will turn. i have spark, we checked that and there was fuel down on the spark plugs. push starting doesn't seem to work either. starter fluid doesn't work.
i don't get it, this car ran so fine before.
but yeh thought i'd update this and thanks everyone for your input.
i doubt that, it's been sitting long enough to dry out i believe then the same thing happens again. a bearing has been mentioned (crank shaft?)
thanks for the reply
It has little or no compression. change the head gasket my buddys b16did the same thing it was running then one day supossedly it shut off but I dont know the truth he wont say.
Turned out the head gasket was blown after I changed that it started right up
