Pressure switch by pass.. Then new code 21 comes up (solenoid)
Well, my problem is when vtec engages itll engage for a good two-three gears then the pressure switch code will come on and vtec will instantly stop working.
-Code 22 (pressure switch)
- I did the by pass from pin A4 to D6.. i ran a jumper wire between the two (correct?)
- The code 22 goes away, but then a code 21 comes up (solenoid) and vtec does not work at all
Any suggestions or help? thanks
PnkRokCountryboy
Sep 2, 2007 02:21 PM
