which cams should i go with?
i have a ls block with ctr pistons. stock b16 head with itr intake manifold and thorttle body and ctr cams and hytech header. got the car tuned and the tuner said the cams were to small. the tuner recommended skunk2 stage 3
want to hear what some people think of what cams i should go with.
no joe didn't tune it someone else did. what about the tuner series stage 3? what do you think about them.
I was also thinking about changing the intake manifold to a jg victor x and bigger throttle body. would there be any gains.
imo s2s3 are still too big for a stock head,but thats me. If you are staying w/ stock head, s2 stage 2's would be a good choice. If you get a P&P head then skip the stage 3 and go toPro1 or pro2.,,,, keep the itr manifold and get it ported and port match a 68mm tb. You asked me for my thoughts, I gave them. Good luck.
get a port and get some pro2's. that would be your best overall gain. port match the intake mani to the head and get a 68mm throttle body and port match the manifold for it. ull see some really nice gains that way.
People forget that stock Honda heads flow pretty well as they are and "porting and polishing" is not an absolute requirement to make power, especially for street daily driven cars. If you were racing A LOT and were looking for max power I would consider porting the head but it is my personal belief that most people really don't need it or at least put too much emphasis on having it done.
S2S3's aren't the best choice of cams for your setup, I'd think the pro 1 / M22xx would be good choices for you and make great power. You're still only a 1.8L so the pro 2's might be a little bigger than you need/want.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja »</TD></TR><TR><TD CLASS="quote">Heard alot of good things of the buddy club spec IV's over the Sk2 stage 2 and 3's.</TD></TR></TABLE>
BC 4's have a larger primary lobe than the S2S2's but the exact same Vtec lobe so they should make better low to midrange but equal top end to the S2S2's. Pro 1 style cams with their newer technology (profile) would be a better overall choice and should make more power overall.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">
BC 4's have a larger primary lobe than the S2S2's but the exact same Vtec lobe so they should make better low to midrange but equal top end to the S2S2's. Pro 1 style cams with their newer technology (profile) would be a better overall choice and should make more power overall.</TD></TR></TABLE>
y dont i believe that the skunk2 pro2's are the same as the bc4's aside from the larger primaries??? so ur telling me that the skunk2 pro2's are a 302-306 degree cam and have a 12.xx mm lift??? last time i checked skunk2 didnt make anything that large and skunk2's primary lobes imo are weak. are they really that big????
o and bc4's need a high comp ratio to really make power i would use them unless i was in the 12.0 or higher range. but thats just me
RaceCarRyne
Jan 14, 2006 07:14 AM
