Do I need a camber kit?
Old Sep 1, 2007 | 12:21 AM
Bruce Banner's Avatar
Default Do I need a camber kit?
Following are results of my alignment
Front Left
CAMBER
Min: -1.0
Max: 1.0
Before: -1.0
After: -1.0
CASTOR
Min: 2.0
Max: 4.0
Before:1.9
After 1.9
TOE
Min: -0.13
Max: 0.13
Before -.4
After: 0.00
Front Right
CAMBER
Min: -1.0
Max: 1.0
Before: -1.6
After: -1.6
CASTER
Min: 2.0
Max: 4.0
Before: 2.9
After: 2.9
TOE
Min: -0.13
Max: 0.13
Before: -0.35
After: 0.05
Rear Left
CAMBER
Min: -1.0
Max: 0.0
Before: -0.4
After: -0.4
TOE
Min: -0.00
Max: 0.16
Before: 0.00
After: 0.10
Rear Right
CAMBER
Min: -1.0
Max: 0.0
Before: -0.6
After:-0.8
TOE
Min: 0.0
Max: 0.16
Before: 0.60
After: 0.10
How does that look?
One tire that I saw the most excessive inside wear was the front right. Car was recently lowered.
Old Sep 1, 2007 | 05:44 AM
TheMuffinMan's Avatar
He knows where you live!
toe is what eats stuff up the most, and it looks like your toe is fine, just read the results
so long as the "after" is between "max/min" you are fine
Old Sep 1, 2007 | 04:50 PM
Default Re: (TheMuffinMan)
Only thing that I notice out of whack the most is the front right camber, it's out of tolerence
Old Sep 1, 2007 | 04:56 PM
someone else's Avatar
It Wasn't Me!
Default Re: (Bruce Banner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">Only thing that I notice out of whack the most is the front right camber, it's out of tolerence</TD></TR></TABLE>
The whole right front is out of whack. The caster and camber are significantly different than the left side which usually means there is a bent component somewhere. Although the differences are small enough that you really shouldn't notice much when driving.
The only time the right front camber could be a problem is if the toe gets out of spec. Too much camber with a bad toe setting will eat a tire in nothing flat.
Old Sep 1, 2007 | 05:16 PM
Default Re: (someone else)
so a front camber kit is necessary, how about rear?
Old Sep 1, 2007 | 07:38 PM
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">so a front camber kit is necessary, how about rear?</TD></TR></TABLE>
I wouldn't. As long as it doesn't pull you shouldn't have any problems. I see cars with that kind of camber all the time without tire wear issues.
Old Sep 1, 2007 | 09:48 PM
isn't the 1.6 camber I have on the front right a BIT extreme?
Old Sep 1, 2007 | 10:51 PM
It Wasn't Me!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bruce Banner &raquo;</TD></TR><TR><TD CLASS="quote">isn't the 1.6 camber I have on the front right a BIT extreme?</TD></TR></TABLE>
It really shouldn't cause you any problems as long as the toe is in. Toe has a much greater affect on tire wear than camber.
Old Sep 4, 2007 | 11:55 AM
Really?
I always thought the camber would affect the tire unless it;s straight.
Old Sep 4, 2007 | 12:53 PM
It Wasn't Me!
When you get into lower profile tires on a daily driver camber can cause some uneven wear but even then not much. It takes quite a bit of camber to cause uneven wear. Or like I said. Camber and Toe out of spec at the same time will shred tires quickly.
Old Sep 4, 2007 | 12:58 PM
Camber kits ftl
Wicked high negative camber ftw
Old Sep 4, 2007 | 01:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Camber kits ftl
Wicked high negative camber ftw</TD></TR></TABLE>
Tires that last FTW.
o.k, so I guess I'll ride this out and see how the wear goes.
Francesco
Honda S2000
30
Nov 23, 2006 03:56 PM
eagleclawracing
Oct 3, 2006 10:48 AM
DougNuts
Suspension & Brakes
14
Mar 10, 2006 01:06 PM
saxqtzk
Suspension & Brakes
Jun 3, 2005 01:48 PM
mr tl
Sep 6, 2002 05:34 PM
