96 fuse box
Old Aug 31, 2007 | 11:39 PM
Tyler Con's Avatar
Default 96 fuse box
does anybody know what fuse it is for the light above my head? I dont have the diagram.
Old Aug 31, 2007 | 11:45 PM
Tyler Con's Avatar
Default Re: 96 fuse box (Tyler Con)
Nevermind, i found a diagram
Old Sep 1, 2007 | 12:03 AM
NOFX's Avatar
H-T White Ops
If you haven't already, check this link, from the FAQ at the top of the page.
https://honda-tech.com/zerothread?id=1966666
Old Sep 1, 2007 | 12:07 AM
Tyler Con's Avatar
Default Re: 96 fuse box (NOFX)
I saw that, and I checked all my fuses. I tried changing the light bulb, but it still isn't working do you know anything else I could try?
Old Sep 1, 2007 | 06:33 AM
Syndacate's Avatar
Do you have an aftermarket radio?
'96-'98 civics had the dome light wired through the radio (the brain & antenna of the keyless entry is mounted there) so when you unlocked it with the keyless entry, the dome light turned one.
Unless you rewire it to the door switch directly, it won't come on when you open the door. BUT, it should still turn on when you turn the switch on.
If: Off & Door = Off, but On = On
Rewire to switch - that's most likely your problem.
Old Sep 1, 2007 | 01:57 PM
Tyler Con's Avatar
Default Re: 96 fuse box (Syndacate)
Yes I have an aftermarket radio but I dont remember it working before I installed it either.
The-Kid
May 8, 2020 06:25 PM
dadrought6
Oct 21, 2009 11:38 AM
scartail
Feb 15, 2005 05:07 AM
ringerracer
21
Nov 3, 2004 07:40 AM
hagrid
Nov 22, 2002 08:26 PM
