96 fuse box
H-T White Ops
Re: 96 fuse box (Tyler Con)
If you haven't already, check this link, from the FAQ at the top of the page.
https://honda-tech.com/zerothread?id=1966666
Re: 96 fuse box (NOFX)
I saw that, and I checked all my fuses. I tried changing the light bulb, but it still isn't working do you know anything else I could try?
Do you have an aftermarket radio?
'96-'98 civics had the dome light wired through the radio (the brain & antenna of the keyless entry is mounted there) so when you unlocked it with the keyless entry, the dome light turned one.
Unless you rewire it to the door switch directly, it won't come on when you open the door. BUT, it should still turn on when you turn the switch on.
If: Off & Door = Off, but On = On
Rewire to switch - that's most likely your problem.
ringerracer
21
11-03-2004 07:40 AM
