Valve cover gasket
Old Jun 14, 2002 | 06:02 PM
127.0.0.1's Avatar
Default Valve cover gasket
I'm going to be polishing my valve cover tommorow morning and was just wondering if I have to replace the gasket when I replace it?
Old Jun 14, 2002 | 07:17 PM
Briman2021's Avatar
Default Re: Valve cover gasket (95'd15b7)
From what I have read, every place that I have seen says that you should.
I haven't done this myself, but this is what I have heard.
BTW, tell me how it turns out, and if possible, pics would be appriciated, b/c I want to do this sometime soon.
Thanks!!!!
[Modified by Briman2021, 4:17 AM 6/15/2002]
Old Jun 14, 2002 | 07:18 PM
DragII's Avatar
25 Year Member
Default Re: Valve cover gasket (Briman2021)
you don't replace it unless it is dried, or stretched out.
Old Jun 14, 2002 | 07:42 PM
crujones's Avatar
i just replaced my valve cover, and used the same gasket. If it's in good shape, you should be aiight. Just be gentle with it, and check for cracks. Good luck.
Old Jun 15, 2002 | 12:10 PM
quik2kSi's Avatar
i stripped and painted mine cast iron and didn't replace the gasket...as long as it's not dry rotted you will be fine.
depo
Mar 23, 2019 09:37 PM
dc5tegk20
Aug 24, 2006 12:40 AM
crx_88_si
Jul 29, 2004 08:47 AM
type Gendy
10
Sep 6, 2003 10:44 AM
B18C-Hatch
May 19, 2003 02:44 PM
