crx with integra engine fuel pump problem
Old Aug 31, 2007 | 11:28 PM
riyakhan's Avatar
Default crx with integra engine fuel pump problem
Hi,
guys i need help i bought 89 crx with integra engine dohc vtec 1.8 problem is fuel pump my car somtime it doesn,t start it cranks when it starts and i drive it stumbles it doesnt go smooth.
will a walbro 255 LPH fuel pump will fit in crx tank or do i have to do modification. please help me with your suggestion.
Old Sep 1, 2007 | 03:14 AM
abnaasefmb's Avatar
Default Re: crx with integra engine fuel pump problem (riyakhan)
Translation
Please help. I purchased a 89 crx with a b18b, the problem I’m having is; sometimes when I crank the car it will start but not always. When it does start the engine will stumble and I have hesitation while trying to drive. I think it might be the fuel pump. Should I replace it with a walbro 255 and what if any modifications will be needed? Thank in advance because I don’t know how to search.
I don’t think it is your fuel pump. Have you replaced your fuel filter an 18 yo fuel filter could be clogged. Also do a basic tune up and then start from there. That way you will not be taking shots in the dark. Also the walbro will work and does fit, mine came with a kit that had a couple of hoses and crap. You will have to drop the fuel tank to replace it and it does have a tendency to up the fuel pressure making the car run rich.
Old Sep 1, 2007 | 05:08 AM
perseverance's Avatar
what type of gas are u running? i have a 90 civic with lsvtec and if i run cheap gas, or i'm low on gas... it'll hesitate. then again my motor was built for boost and i already have a walbro installed
hmonkey86
Feb 7, 2012 05:02 AM
gonzalezjk
Classic Hondas
Apr 19, 2008 05:45 PM
riyakhan
Sep 11, 2007 05:22 AM
riyakhan
Aug 8, 2007 02:54 PM
