Need Help, some problems with my Integra and need some suggestions.....
Old Aug 31, 2007 | 07:44 PM
Buktheng's Avatar
Default Need Help, some problems with my Integra and need some suggestions.....
Ok, I bought a 94 LS sedan and it's having some damn problems already. First thing, on the highway home driving from the place I bought it from, the freaking heater hose exploded! I looked in the engine and there was water all over the engine and it squirted onto the wind shield. On the end where its connected to the side of the engine, there was a huge gash with smoke coming out.
Another problem is, the oil light is coming on and I just got done changing the oil hoping it'll fix the problem. I turned on the car and drove around the block and the oil light still is on and just driving around the block is making the car overheat. I popped the hood and can really feel the engine over heating. I saw the radiator fans spinning and all and I feel the air blowing at me which is weird cause that I never felt that with any car before.
What do you guys think can be the problem? What do I gotta check or fix? I bought a new thermostat also but I don't think that's gonna fix anything. Help me out! Thanks!
Old Aug 31, 2007 | 08:18 PM
hatchling37's Avatar
Default Re: Need Help, some problems with my Integra and need some suggestions..... (Khoifather)
Are you throwing any CEL's? Just replace that heater hose and then properly burp the system. For your oil light, I would suggest if all other things don't help, you might need to check out your oil pressure sending unit.
Old Aug 31, 2007 | 09:48 PM
honda1982's Avatar
okay how many miles on you 94LS??? when did you last got a new T-belt & water pump change? that can cause your overheating. Have you bleed the Radiator after you replace the heater core? what thermostats are you using? OEM Honda or cheapo Auto Zone? Oil pump replace YET?? check your oil level?
Old Aug 31, 2007 | 09:50 PM
honda1982's Avatar
I forgot but if you Blown you headgasket that can cause the overheating. What color are the oil? milkshake like???
Old Sep 1, 2007 | 05:30 AM
Buktheng's Avatar
Default Re: Need Help, some problems with my Integra and need some suggestions..... (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Are you throwing any CEL's? Just replace that heater hose and then properly burp the system. For your oil light, I would suggest if all other things don't help, you might need to check out your oil pressure sending unit.</TD></TR></TABLE>
No I'm not throwing any cel and yesterday I went to both Pep Boys and Auto Zone looking for a new heater hose and they didn't have it so I just had to cut the end of the heater hose until the part that gashed open wasn't there anymore.
Old Sep 1, 2007 | 05:32 AM
Buktheng's Avatar
Default Re: (honda1982)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda1982 &raquo;</TD></TR><TR><TD CLASS="quote">okay how many miles on you 94LS??? when did you last got a new T-belt & water pump change? that can cause your overheating. Have you bleed the Radiator after you replace the heater core? what thermostats are you using? OEM Honda or cheapo Auto Zone? Oil pump replace YET?? check your oil level?</TD></TR></TABLE>
There's about 140K miles on the car. I really don't think this guy replaced anything on the car since he had it. Looks like I"ll have to get new timing belt, water pump, and all that stuff. I bought a thermostat from Auto Zone, Duralast brand. I guess that was a bad idea huh?
Old Sep 1, 2007 | 05:33 AM
Buktheng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda1982 &raquo;</TD></TR><TR><TD CLASS="quote">I forgot but if you Blown you headgasket that can cause the overheating. What color are the oil? milkshake like???</TD></TR></TABLE>
I kinda did look milkshake like when I replaced the oil cause the oil was pretty dark.
Old Sep 1, 2007 | 06:46 AM
gsrob's Avatar
I couldn't find a heater hose for my integra at autozone either, had to end up getting it from Acura. But I just had the same thing happen. The heater hose right behind the top radiator hose was apparently really crispy and blew out a nice split on the face of it. Really easy to replace though, I think the new hose was like $24 from the dealership.
Old Sep 2, 2007 | 11:04 AM
TIMMY4TOES's Avatar
agree, he should check if water is going into his cyclinder walls or if compression is going to radaitor, if there is you will see airbubbles or oil in the radiator
hope this helps
Old Sep 2, 2007 | 01:45 PM
Buktheng's Avatar
It may be the oil pump. When I turn on the car, I hear a noise coming from it. How can you tell if your oil pump is dead?
Old Sep 6, 2007 | 08:08 AM
TIMMY4TOES's Avatar
Default Re: (Khoifather)
take off timing belt cover and inspect it very throughly
Old Sep 6, 2007 | 10:41 AM
dc2 frm da island's Avatar
Default Re: (TIMMY4TOES)
IF I WEER U, I WOULD RETURN IT.. DID DA PREVIOUS OWNER MENTIONED ANYTHING ABOUT THE CAR? OR U BOUGHT THE CAR AS-IS? CUZ IF U DID BOUGHT IT AS IS, THEN U CANT RETURN IT ANYMORE
nandowln
Apr 30, 2015 08:18 AM
jdm21
24
Apr 23, 2009 05:13 PM
gavhowe
May 6, 2003 06:04 AM
TheNanashi
Mar 30, 2003 11:13 AM
