stuch dizzy rotor, need help please!
so im changing my cap and rotor and the damn rotor wont come off. the screw is out, but the rotor isnt budging. i even took the distributor off to try and get a better grip on it, but it still isnt moving.
it looks like it might have gotten a little rusty or something, would it be ok to hit it with some pb blaster or no? need some help before i say f' it and cut it off with the dremel.
thanks in advance!
thanks in advance!
Don't see why it wouldn't be okay- it's sealed. I would just try to wipe or blow out the excess lube before you put it back together.
i would hesitate to spray anything inside there.... try and cover everything if you do!! sealed or not its an expensive part to replace
Tealeg88
10
Jan 15, 2006 08:43 PM
