obd 0 distributor cap
Hi my name nick and i am new on here. I have a crx with a obd 0 b16a and i need a msd distributor cap. Lot of people told me dif things and i couldnt find one with the same bolt pattern. Does anyone know which one i need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">OEM HONDA!</TD></TR></TABLE>
x2. why do you "need" an MSD cap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niklet1 »</TD></TR><TR><TD CLASS="quote">because i have a msd 6al box and a blaster 2 coil and i was wanting to run it with a pro cap</TD></TR></TABLE>
well if you already have it
all obd0 dizzy caps are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF »</TD></TR><TR><TD CLASS="quote">
all obd0 dizzy caps are the same.</TD></TR></TABLE>
Not quite^^ Im pretty sure the older pre88 ones are different
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
Not quite^^ Im pretty sure the older pre88 ones are different</TD></TR></TABLE>
well he's asking about a 1G B16.... all 88+ obd0 caps are the same
exactly... there were no "pre 88" obd0 b16's. maybe a zc... but dudes right, oem honda is best!!!! that is what the engine was designed to run on. its like when people get "super, ultra, high iridium racing spark plugs"
the ngk will always be the best honda plug... who do you think makes spoon plugs?
GL man!!!
</TD></TR></TABLE>exactly... there were no "pre 88" obd0 b16's. maybe a zc... but dudes right, oem honda is best!!!! that is what the engine was designed to run on. its like when people get "super, ultra, high iridium racing spark plugs"
GL man!!!
So all obd 0 caps have the same bolt pattern. Because somebody told me to try a 94 del sol vtec and it didnt work. If i get one for a da integra it should work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by niklet1 »</TD></TR><TR><TD CLASS="quote">So all obd 0 caps have the same bolt pattern. Because somebody told me to try a 94 del sol vtec and it didnt work. If i get one for a da integra it should work?
yes. as long as its 90-91 it will work.
