how to loop powersteering after removing?
Old Aug 31, 2007 | 12:00 PM
Vtec315's Avatar
Default how to loop powersteering after removing?
i have removed the power steering from my 96 integra gsr. now i want to no how to loop the system?
Old Aug 31, 2007 | 12:05 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: how to loop powersteering after removing? (Vtec315)
this is how i did my with a breather system using a clutch resivor even better than the looped way
Old Aug 31, 2007 | 01:49 PM
RCautoworks's Avatar
You can just leave it open, nothing will happen. Talked to a few guys who have been doing it this way for ages and have been fine, I was always the assumption that it should be looped as well.
Old Aug 31, 2007 | 01:53 PM
muvian's Avatar
Default Re: how to loop powersteering after removing? (RCautoworks)
the hoses on mine have been cut and left open for god knows how long without problems, im sure that the dirt getting in there isnt good for the seals though, but it was like that when i bought it and just never took the time or the money to fix it right
well you learn something new everyday my way is better cuz steering isnt that hard cuz its not looped it has a resivor so no pressure is built
Old Aug 31, 2007 | 05:22 PM
tyco's Avatar
Default Re: how to loop powersteering after removing? (DOHCgarage919)
did the same with mine used a clutch res. and tucked it where it cant be seen dont forget to change rack. pinion
Old Aug 31, 2007 | 06:22 PM
Default Re: how to loop powersteering after removing? (tyco)
huh why wud you change the rack and pinion??? if you looped it why wud you get a diff rack and pin. make no sense please clarify
Old Aug 31, 2007 | 11:00 PM
tyco's Avatar
opps sorry did not clarify, some people change rack. opinion if not looped, changing it to non PS rack. pinion is advisable because sooner or later your PS rack pinion will end up giving up
Old Sep 2, 2007 | 11:50 AM
JDMB20TDA's Avatar
i just plugged it off
JOSHGLISSEN
Jun 18, 2008 11:15 AM
z2weaver
Sep 21, 2007 03:57 PM
EF9 JAMS!!!
Oct 21, 2005 11:58 AM
FB in SA
Feb 20, 2004 09:24 AM
mr_mbuna
Jan 16, 2003 06:38 AM
