OBD1 Single cam dizzy on a crx
Old Aug 31, 2007 | 10:30 AM
BlakeJ53's Avatar
Default OBD1 Single cam dizzy on a crx
I have a 90 hf with a si motor, I am swapping out the dizzy for a OBD1. I think I have the wiring figured out but the dizzy is rotated forward so all the holes will line up. Will that effect how the car runs? Thanks in advance Jordan
Old Aug 31, 2007 | 10:40 AM
Malgerus's Avatar
Default Re: OBD1 Single cam dizzy on a crx (BlakeJ53)
If you're running a D16Z6 distributor, then you need to modify the distributor legs to make it work properly.
If you're running a D16Y8 distributor, it will bolt on and mount just as well as the stock one does. And yes, it will work just fine with an OBD-I ECU.
Old Aug 31, 2007 | 12:32 PM
BlakeJ53's Avatar
I ment to say I am running a crx si motor not a z6 or a y8
Old Aug 31, 2007 | 06:47 PM
dem0nk1d's Avatar
if your ride is setup to run obd1, then yes you can use the obd1 dizzy. but if it's obd0 then you can only use obd0. i know all the sensors are the same but the crankangle sensor has an different amount of teeth
Old Sep 2, 2007 | 02:11 PM
BlakeJ53's Avatar
any body at all?
Old Sep 2, 2007 | 02:21 PM
dr_latino999's Avatar
Was your questioned not answered?
ryanangelo212
Mar 18, 2013 12:23 AM
VegasInvasion
Jul 1, 2010 10:49 AM
lilsicsoul
Jan 23, 2009 03:52 PM
Ocnaj
14
Jun 30, 2008 06:11 AM
EF9ZC
12
Mar 8, 2006 04:59 PM
