wierd turbo timer problem
I installed my Greddy turbo timer using the specific DC2 harness (from lightning motorsports) and all appeared to be working fine however when i indicate, or turn on the wipers or put the car into reverse it turns off then back on again.
The car is a 1996 JDM Integra type R turbo
Any help would be much appreciated.
Cheers
Russ
Cheers
Russ
If the power cuts off then back on, my first guess would be something to do with the grounding of the unit OR because blinkers and what not have relays in their respective systems, when say the blinker is between 'blinks' the power is by passing and grounding back to the battery. Maybe causing your problem.
Double check the part numbers of each piece as well as the scematics AND see if the timer is properly grounded.
Etorres325
Mar 31, 2010 05:30 PM
