chipped p28 or p72
Which ecu is best to work with a ls/vtec setup? and why??? currently have greddy Headers, apexi cat-back, rc injectors 310cc, aem fuel rail, regulator & cams...
Need some help fellas!!!
chipped p28...and get it tuned, especially since its a lsvtec set up, your running bigger injectors and you have aftermarket cams. Which head are you using though?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine »</TD></TR><TR><TD CLASS="quote">wont a chipped p72 work?</TD></TR></TABLE>
yes, but honestly..the obd1 p72 ecu is actually worth more as a stock ecu than it is chipped. Plus its a little harder to find. The p28's are abundant and cheaper.....its more cost effective I suppose
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">really you could use any obd1 ecu. p28's are just easier to find and a lot cheaper.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ »</TD></TR><TR><TD CLASS="quote">
yes, but honestly..the obd1 p72 ecu is actually worth more as a stock ecu than it is chipped. Plus its a little harder to find. The p28's are abundant and cheaper.....its more cost effective I suppose</TD></TR></TABLE>
no wonder p28's are so commonly used
I can get my hands on both just want to know the difference...will my car run differently???between the two?
thanks guyz for your input...
DeEmAn!
DeEmAn!
a p72 has a knock board for the knock sensor. but you can disable it using just about any engine management. and it can control iab's if you're still using them.
Jdmlifetyper
Mar 26, 2012 11:35 PM
Kiniku Chunks!!!
Aug 28, 2006 10:51 AM
vizsual00
18
Oct 23, 2003 02:33 PM
