Blueprint???
Old Aug 31, 2007 | 05:43 AM
DA_JDM's Avatar
Default Blueprint???
Do you guys usually have your fresh built blueprint or its not necessary??? I have it blueprint the first time but now i have to re-built it again and im not sure if i wanna pay the 1000$ for it again!!!
Discuss...
Old Aug 31, 2007 | 08:28 PM
DA_JDM's Avatar
Default Re: Blueprint??? (DA_JDM)
Old Aug 31, 2007 | 11:18 PM
ExospeedAMcrx's Avatar
any build should be measured as if its a brand new build. tolerances change after use. You can take a chance on assuming that everything is still the same clearances and uses the same bearings, etc. but the proper way should be to act as if each rebuild is a new build. It also depends on why you are rebuilding it. If its gone through alot of wear and tear? spun bearing? detonation? etc...
Old Sep 1, 2007 | 04:38 AM
hybrid2007's Avatar
If it was me i would blueprint. You dont want to be rebuilding for a third time.
Old Sep 1, 2007 | 07:59 AM
spun Vtec's Avatar
Default Re: Blueprint??? (hybrid2007)
what all is involved in "blueprinting"??
Old Sep 1, 2007 | 09:14 AM
DA_JDM's Avatar
rebuilt because of some dropped valves
Old Sep 1, 2007 | 09:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA_JDM &raquo;</TD></TR><TR><TD CLASS="quote">rebuilt because of some dropped valves </TD></TR></TABLE>
what did it do to the block? the pistons destroyed?
Old Sep 1, 2007 | 06:59 PM
DA_JDM's Avatar
Default Re: Blueprint??? (ExospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
what did it do to the block? the pistons destroyed? </TD></TR></TABLE>
Yeah only one...piston #4...my sleeve were not crack but still have to go 82mm!!!
Old Sep 1, 2007 | 07:06 PM
all-mtr-teg's Avatar
I would just get a new piston and balance the whole assembly if the rod wasn't damaged.
Old Sep 2, 2007 | 07:43 AM
DA_JDM's Avatar
Default Re: Blueprint??? (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">I would just get a new piston and balance the whole assembly if the rod wasn't damaged.</TD></TR></TABLE>
All the exhaust valve touch the top of the piston...i have a lot of debrits of the 4 destroyed velve and the piston too...they say i dont have the choice and go 82mm...and i have to change the rod of the destroyed piston too...all other 3 were untouched
Old Sep 2, 2007 | 08:58 AM
If you're interested, I have a brand new set if 82MM RS Machines ITR pistons, brand new Swirl Polished vavles from SI Industries, they are a Southern California manufacturer for race car components, stock gsr rods, type r/gsr acl bearing set, type r/gsr arp rod bolts, everything brand new, was gonna rebuild my other 98 gsr block. But now i don't have time cause of school. Let me know if you wanna buy any of this, i'll let it go for cheap
01em2
Honda Civic (2001 - 2005)
Jan 30, 2008 02:33 AM
ls19integra95
Nov 7, 2007 08:46 PM
EG6_DREAMS
Sep 13, 2007 08:55 PM
mattssi
Mar 6, 2004 05:02 AM
The Punisher
May 28, 2003 08:21 PM
