98 dx w/d16y8 con. ???
Im finishing my conversion and i was going to start the car with the p2e computer? If not where do i get the jumper for the p2p ecu. I put a d16y8 auto on a dx standard trans with a lighten flywheel and clutch. Theres a B16 throttle body. Does all of this make sense to anyone who can help... I changed the sensor on the intake to a two wire from three... and de-pin on the ecu side so i dont understand why my p2p ecu dosnt plug in?
if it is a rectangle shape p2p it is 96-98 obd2a, if it is a square shape it is 99-00 obd2b. What year engine did you put in? Also did you retain your engine harness or used a different one?
MilanoRed_EJ8
Mar 8, 2007 10:29 AM
how do u figure out the year? i think i have a 2000
