88 hf suspension technique sway bar install
Old Aug 30, 2007 | 06:49 PM
SFlCrx's Avatar
Default 88 hf suspension technique sway bar install
i need advice from people who have installed this sway bar on an 88 non si crx only.
did you get the adapter kit for the 88 or did you fab it up?
also i would like some pics i don't know if my koni yellows and ground control set up will affect the install and my exhause ends right before the 90 degree bend so that woun't be an issue. i have search and found some good info but most of the pics do not show up and i have seen the pics of the crx with the advanced struts but i don't think that is an 88 non si. and help would be great thanks.
Old Aug 31, 2007 | 08:10 AM
SFlCrx's Avatar
any one
Old Aug 31, 2007 | 05:39 PM
SFlCrx's Avatar
wow i guess i'm going to be the first person to install a st rear sway bar on a 88 crx non si. damn it feels good to be a gangsta
Old Aug 31, 2007 | 05:49 PM
EFM_ookie's Avatar
Default Re: (SFlCrx)
You could always use some newer or aftermarket LCAs. I did The ST rear sway bar on my 88 civic hatch and just upgraded the LCAs and threw on some koni shocks.
I can post some pics if you would like. I suggest just going to the junkyard and gettin the 89-91 lcas if you are already going to upgrade your shocks
Old Aug 31, 2007 | 06:21 PM
SFlCrx's Avatar
Default Re: (EFM_ookie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFM_ookie &raquo;</TD></TR><TR><TD CLASS="quote">You could always use some newer or aftermarket LCAs. I did The ST rear sway bar on my 88 civic hatch and just upgraded the LCAs and threw on some koni shocks.
I can post some pics if you would like. I suggest just going to the junkyard and gettin the 89-91 lcas if you are already going to upgrade your shocks </TD></TR></TABLE>
i alreay have koni yellows. i don't think the aftermarket lcas are worth the money, but thanks for the reply. It really pisses me off that 90% of my post on here is from helping people or giving them advice but when i need some help no one replys
Old Aug 31, 2007 | 06:38 PM
EFM_ookie's Avatar
I have seen ppl make custom brackets for the 89-91 style LCA but never for the 88. I would just Buy the conversion kit from summit since you already have new shocks
Old Aug 31, 2007 | 09:02 PM
UltimX's Avatar
i rmemeber someone doing it but i don't remember the link. ST sells a adaptor for the 88 specific ones. call them
Old Sep 1, 2007 | 09:51 AM
SFlCrx's Avatar
all right thanks. i order the kit. too bad its on back order so i won't be able to put the sway bar in for at least a month. So how much of a difference did it make and which settings are you guys on?
Old Sep 1, 2007 | 03:50 PM
UltimX's Avatar
its a nice mod. i with the lowest setting and if you want more then bump it up. thats all i can say, it all depends on personal preference.
Louie B.
43
Dec 11, 2007 09:15 AM
SFlCrx
Jul 19, 2007 04:47 PM
allmotor215
Suspension & Brakes
10
Feb 19, 2006 04:04 PM
EF8 JUNKIE9
Apr 13, 2005 09:15 PM
Therapy
Jan 6, 2004 07:51 PM
