Pretty Kool Idea Need Help With
Guys i have been plotting on this. Beings how i havn't seen it done.
im trying to find a way to bond the 2 front fenders to the hood so when i pop the hood and lift it the fenders follow mostly i want to have it for the idea sake
Anyone got any tips to steer me in the starting direction
1996 Acura Integra b18a1
Other then it being kinda retarded, and you would have to find a new way to secure the fenders when the hood is closed.
Best bet would be to weld together the fenders with the hood,
and smooth it out with w/e bodyfiller you like.
But if all you did was that, and left the fenders unbolted, they'd be kinda floppy.
why would you wanna do that? You would have to support the fenders or else they will flop around at high speed, then you would have to unbolt them everytime you pop the hood. Unless you plan on making it a complete show car and tow it everywhere. I would just buy the one piece front end.
From: Why To Steal My Car, NC, United States Of America
you didnt really come up with this idea its been out for a while like said one piece front end etc or like drag cars front ends
well even as it may its my project car mostly for show not a casu driver for a 1996 with 100k on it and a rebuid head i think it will be a fn flip to toss as my m8s with the split hood style
Ok i started working im trying to serce the fenders by light weight reinforcement i used 2x door joints to keep a strong hold, and when the hood pops to be able to fold up under the hood with help of a placed hood latch. now im going to use Flexo Bonda Putty with a mix of hose hold joint compond and plumbers foam to take the space up. also i used a pants style butten to hold the fenders to the front bmper/side skirt. once everything is dry ill remove the buttens and test drive ill be posting pic's as well
oky guys projects almost done figre ill be done tomorrow night. look forward to your comments on the pics
so far the hood opens and shts fine with not problems and the fenders line p and the door latches hold the fenders far better then i thought.
so far total expense for this is follows
12$ for 2 drill bits (broke both)
3$ for 4 door hinges
4.99$ for plumbers fome
the hood lifts normally like regular acura hoods
the latches hold good under the hood aswell
i sealed the latches with screws and a bit of the god send called JB weild
Modified by Ludeist at 4:04 PM 9/2/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keeks707 »</TD></TR><TR><TD CLASS="quote">Cant wait to see finished product!</TD></TR></TABLE>
