1992 honda prelude H2.3 SI -Automatic
Old Aug 30, 2007 | 06:23 PM
Ludeist's Avatar
Default 1992 honda prelude H2.3 SI -Automatic
Im trying to figure out why the D4 light always blinks reguardless of what gear I am in seems to be a solid green apon start but then within 5 min's the light starts to blink even if im in reverse d1,d2,d3 the d4 light remains blinking
Any idea's?
Old Aug 30, 2007 | 06:49 PM
Ludeist's Avatar
Default Re: 1992 honda prelude H2.3 SI -Automatic (Ludeist)
Bump
Old Aug 30, 2007 | 08:28 PM
PirateMcFred's Avatar
Read your owner's manual. There's a problem with your transaxle. The blinking D4 is trying to tell you to stop killing it.
Old Aug 31, 2007 | 06:18 AM
Jagan'92's Avatar
it's a transmission error code just like the CEL, jump the connector and check it the same way to get the code.
check your atf level. are there any other symptoms?
Old Aug 31, 2007 | 08:50 PM
Ludeist's Avatar
no none the trannie does not slip and shifts fine. no high balling. shifts at 7 if i get on it and shifts at 3/4 on case driveing
Old Sep 1, 2007 | 08:14 AM
Ludeist's Avatar
bump
Old Sep 1, 2007 | 10:33 AM
Default Re: (Ludeist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan’92 &raquo;</TD></TR><TR><TD CLASS="quote">it's a transmission error code just like the CEL, jump the connector and check it the same way to get the code.</TD></TR></TABLE>
Listen to the man. The car's trying to tell you what's wrong with it. Read the code and address the problem.
Get a manual and look up what the code is then you'll have the instructions on how to fix it too. Bumping this again and again is not going to get you a better answer.
Pirate
HondachrisEJ1
Feb 16, 2009 06:51 PM
KleenL
Jan 14, 2008 09:29 AM
Arch-Angel
Jul 11, 2004 05:15 PM
shettysaab
May 18, 2004 12:38 PM
thehondaguru
Nov 23, 2003 07:38 AM
