I live in Cali what do i need to BAR a b16a????
Old Aug 30, 2007 | 04:46 PM
mynameizstitch's Avatar
Default I live in Cali what do i need to BAR a b16a????
ok i plan on doing the complete jdm first gen b16a obd 0 swap in my 90 crx si. i want to reff it so it is legal here in cali. someone said that this will not be able to pass because i will need some usdm parts on there to be able to bar it. what do i need???
Old Aug 30, 2007 | 04:59 PM
denraweb's Avatar
Default Re: I live in Cali what do i need to BAR a b16a???? (mynameizstitch)
You cannot bar an obd0 b16a because that motor was not offered in the us in those years...you have to convert over to obd1 fully and hope that it passes. Even with the obd1 conversion done right, it does not mean that you will be able to ref it. You do need a us manifold along with a us ecu to pass smog though. The jdm ecu's and manifolds do not pass. Your swap also have to look 100% STOCK. This means no carb legal things like header, intake, exhaust, etc. Some refs will still bar with CARB parts, but to be safe, you need to make it look stock. Also the wiring needs to be done neatly, not hacked together and have masking tape all over it. Again, I repeat, IT NEEDS TO LOOK STOCK AS HELL!!
Old Aug 30, 2007 | 05:15 PM
Default Re: I live in Cali what do i need to BAR a b16a???? (denraweb)
anyone know a shop or place that can do the swap and get the motor in for me? and make it bar legal?
Old Aug 30, 2007 | 08:19 PM
Street Racer X's Avatar
good luck with that, those kinda shops are word of mouth and few and far between, if a shop gets caught passing cars illegally they lose their smog license and its good money. make sure all the vacuum lines are hooked up correctly and your PCV system is all there as well.
Old Aug 30, 2007 | 08:44 PM
crx-b16's Avatar
Default Re: I live in Cali what do i need to BAR a b16a???? (whitecivichatch90)
lol not to bad I got a reffed CRX with a b16 send me a tell or ask me anything...
Blah.
Apr 26, 2010 10:21 AM
jonaldjenkins
Feb 3, 2008 11:12 PM
efboy
Jan 14, 2008 09:15 AM
dem0nk1d
10
Dec 31, 2007 07:15 PM
EF-9SiR
18
Jan 10, 2003 12:10 PM
