I have 2 dead cylinders, please help.
Old Aug 30, 2007 | 10:55 AM
Robert Padron's Avatar
Default I have 2 dead cylinders, please help.
I have a boosted 99 si and I washed the motor this Monday. After washing the motor it started hesitating or stalling. Come to find out that the one and two cylinders aren't working. I changed the plugs and the wires with new ones, and it made no difference. I checked the plugs for spark and there is spark. I installed 2 dsm 395 injectors from an automatic eclipse and stil no difference. I have dsm 450s injectors in it. Is there anything else that it could be? I don't have transportation now and have to bum rides to work please help I've been without my car since Monday.
Old Aug 30, 2007 | 11:13 AM
OLD_HATCH's Avatar
how did you find out it was the 1 n 2 cylinders? Did you do a compression n leakdown test?
Old Aug 30, 2007 | 11:21 AM
I found out because when I disconected the 1 and 2 wire from the distributor there was no difference, then engine kept misfirring. But when I disconected the 3 or 4 wire the engine turned off since it can not run on just one cylinder. Thank you.
Old Aug 30, 2007 | 11:47 AM
JaredKaragen's Avatar
Default Re: (Robert Padron)
did you hose your engine bay down? any chance water got into the dist?
cityofcaterpillars
15
Nov 21, 2017 06:40 AM
Cricketo99
Nov 12, 2014 03:08 PM
JDM B20 EH2
Jan 20, 2011 09:10 AM
