1990 cel codes?
http://www.cb7tuner.com/vbb/showthread.php?t=21259
1. If your check engine light is on, start by going to your passenger side kickpanel.
There should be a blue connector w/2 wires to it like the one pictured below.
Put a paper clip, wire, connector in it to connect the two prongs.
2. Put the key in the ignition, and turn the key 2 clicks to the acc on, where all the lights light up on the dash.
3. You will now watch how many times the CEL light blinks.
a long blink = 10
a short blink = 1
It will repeat after all the codes are done.
4. Compare to this list to see what the problem is:
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Resetting ECU
1. Disconnect Negative battery terminal (never only take off the positive, cuz it can kill the battery when it grounds all the power out, if left for a while)
2. Look in the Underhood fuse box, find the "Hazard" Fuse. Pull it out.
3. Let the car sit for 10-15 minutes
4. Reattach neg battery terminal and put fuse back in
5. Restart car w/nothing on (radio, lights, a/c) and just let it run for a few minutes.
6. Turn off, and then it should be good to go.
a long blink = 10
a short blink = 1
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
Resetting ECU
Code 43 could be a lot fo things.
Best to do a complete tune up.
It could be due to a faulty O2 sensor.
How many miles on the sensor? needs to be changed at 60k mile interval.
If problem persists, check for vacuum leaks.
Vacuum leaks will cause the code 43 fault due to lean condition.
i thought a vacuum leak makes your car run rich, but anyways my buddy just called and said his car was backfiring and missing after he had been driving for about an hour around town, so he floored it and it cleared out, and then ran somewhat okay, after the car had cooled he started and it runs fine now. so any ideas would be great, we will do a full tune up tomorrow first thing
odo53
Apr 8, 2008 10:13 AM
