correct me if I'm wrong
Old Jun 14, 2002 | 01:37 PM
hatchdrvr's Avatar
Default correct me if I'm wrong
It's a bad thing when you pull your #4 plug and find oil on it, then look into the combustion chamber and find oil on the piston, right? any suggestions.
Old Jun 14, 2002 | 01:49 PM
stealthteg's Avatar
Default Re: correct me if I'm wrong (ForceFedEG)
for starters i would run a compression test on all the cylinders. wont fix anything but will give u an idea on what might be wrong. Kinda sounds like a piston ring problem but dont quote me on that...
Old Jun 14, 2002 | 02:14 PM
carcala's Avatar
Default Re: correct me if I'm wrong (stealthteg)
do that and u would cut the possibilities down. Im also thinking piston rings. Do u blow out blue smoke from ur exhaust? If you do most likely its piston rings.
[Modified by carcala, 11:14 PM 6/14/2002]
GTEater
Sep 30, 2010 09:43 PM
LOVEthatDC2
Aug 7, 2009 11:06 AM
rudedawwg
Jun 6, 2009 09:59 PM
IGOTpinkShards
May 28, 2004 10:48 PM
tominos
22
Feb 18, 2003 08:55 PM
