i need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 30, 2007 | 07:01 AM
the_rex's Avatar
Default i need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
so i have a 91crx si 1.6 sohc non vtec (obviously) and iwas going to put a turbo on but i also gotta do pistons rods crankshaft and all that good stuff i was wondering is there any kinda of kit out there for all that and the kit needs to be able to hold the turbo so i need some good rods and pistons and is there any kinda of special things i should look at doing along with the bottom end rebuild plz help needed
Old Aug 30, 2007 | 07:31 AM
Wilky's Avatar
Default Re: i need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (the_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_rex &raquo;</TD></TR><TR><TD CLASS="quote"> is there any kinda of special things i should look at doing along with the bottom end rebuild plz help needed</TD></TR></TABLE>
Well, start with the FAQs at the top of the page.
Then learn to use the search button.
Then... what do you plan on doing with this car? Daily driver, or track only? How much power are you looking to make?
Old Aug 30, 2007 | 07:36 AM
89Turbo_Angel's Avatar
People use "I need help" so loosely around here.
Old Aug 30, 2007 | 08:56 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (89Turbo_Angel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Turbo_Angel &raquo;</TD></TR><TR><TD CLASS="quote">People use "I need help" so loosely around here. </TD></TR></TABLE>
I see you have learned quickly, n00bie.
OP, check out the forced induction forum and possibly http://www.homemadeturbo.com, I KNOW there are many builds around using that motor as a base.
luis80
May 25, 2010 01:14 PM
409 IYCM
Sep 22, 2007 08:08 PM
the_rex
Aug 30, 2007 06:51 AM
nudvl
Sep 2, 2006 05:17 PM
Gsr94black
Dec 29, 2004 10:19 PM
