O2 sensor and poping problem
Old Aug 29, 2007 | 09:19 PM
haroldthefly91crx's Avatar
Default O2 sensor and poping problem
i have had 2 ecus in my crx ls and replaced the o2 sensor and the code keeps comming back,
also there is a poping near the right from wheel, replaced the axel, nothing
any ideas as to what my problems are?
Old Aug 30, 2007 | 02:31 AM
EFin' Kyle's Avatar
Default Re: O2 sensor and poping problem (haroldthefly91crx)
what code? 1 or 2? do u use a secondary O2 sensor. maybe that is it. as for the popping.... maybe wheel bearing. is it only when u turn or is it constant?
-Kyle
Old Aug 30, 2007 | 05:29 AM
Default Re: O2 sensor and poping problem (Good Ol' Kyle)
i am running onbd 0 so i only have 1 o2 sensor with 1 wire
and with a pr4 im throwing code 43 and with a pm6 its code 1. as for the popping it happens all the time but mostly when im turning
bump
Old Aug 30, 2007 | 05:50 AM
EFin' Kyle's Avatar
is ur o2 sensor on the cat or the header? i think ur going to have to run 2 o2 sensors one on the cat and one on the header. and i would guess that the popping is a wheel bearing
-Kyle
Old Aug 30, 2007 | 08:35 AM
but its obd0, im pretty sure that obd0 only has one o2 sensor, i know for a fact the the pr4 only has one so that cant be the problem
perhaps there is a short in the wiring somewhere?
bump
Old Aug 30, 2007 | 11:09 AM
EFin' Kyle's Avatar
when i had an obd0 b16 in my ef i believe i had 2 and i was getting a code 1 cuz i only had the secondary o2
accord2civic2prelude
Dec 12, 2009 03:35 PM
Bossup!
Sep 9, 2009 07:35 PM
vietboiracer0
Dec 30, 2005 08:00 PM
messeduprex
Apr 11, 2005 08:08 AM
scrEaMO Kyle
11
Mar 10, 2005 09:22 AM
