help on retainers and valvesprings
Old Aug 29, 2007 | 09:10 PM
Ek97hatch's Avatar
Default help on retainers and valvesprings
i dunno how to make the title very specific.
I am planning to get rocket motorsports M22x cams, but i want to send my head down to portflow for full head work. My question is: Would it be okay to use their components (portflow retainers and valvesprings) with the M22x cams or should i use the rocket motorsports valvesprings and retainers to go with these cams?
Old Aug 29, 2007 | 10:23 PM
Lscivic1999's Avatar
Default Re: help on retainers and valvesprings (Ek97hatch)
as long as you upgrade your springs and retainers i dont see a problem....but if you can get the same components from them, do it...blox,skunk2,ETC..all of these should be fine...!!!
Old Aug 30, 2007 | 06:00 PM
stumpyf4's Avatar
Portflow should have no issue assembling the valvetrain of your choice.
I would prefer to match the valvetrain to the cams, why?
1) Valvetrain and cams probably have been tried many times and you minimize running into issues with install height and retainer to valve seal contact.
2) Rocket springs and retainers are snap fit so you minimize issues with retainer wear. (don't know if Portflow are snapfit or not).
3) You'll have less issues with warranty (if you have to use it) if you match all components.
Old Aug 31, 2007 | 12:03 PM
Ek97hatch's Avatar
thank guys. i'll wait for the great deals on RM valvesprings and retainers. if not, then i'll use the portflow.
Old Aug 31, 2007 | 02:51 PM
doood's Avatar
been there done that
warning: portflow will not install rocket springs and retainers. i asked before and they wouldnt touch the stuff.
Old Aug 31, 2007 | 05:08 PM
Rocket's Avatar
Default Re: help on retainers and valvesprings (doood)
PF did not like the RM G1 springs.
Our new SL springs spec @ 55lbs on the seat and 180lbs @ 0.500" with 13mm lift capability when the installed heigth is 1.320" (Normal stock height).
Thank you for letting us clear up this "out dated" comment.
Old Aug 31, 2007 | 05:12 PM
doood's Avatar
Default Re: help on retainers and valvesprings (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe &raquo;</TD></TR><TR><TD CLASS="quote">PF did not like the RM G1 springs.
Thank you for letting us clear up this "out dated" comment.</TD></TR></TABLE>
well that's good to know. the springs in question were the older G1's.
Old Sep 1, 2007 | 12:59 AM
Ek97hatch's Avatar
thank you guys for the warning. i appreciate it.
EK-TanK978
Oct 29, 2005 10:13 AM
Ballade
Nov 28, 2004 07:08 PM
MrMike
34
Sep 4, 2004 01:47 PM
redteg1
Feb 15, 2002 09:36 PM
Black R
Jun 15, 2001 06:58 AM
