how to fix cel code 14
Old Aug 29, 2007 | 08:41 PM
94allmotor's Avatar
Default how to fix cel code 14
just bought a 00 civic with gsr swap. its throwing me 2 codes the first code is 1 i know how to fix that because the car has no oxy. sensor. and code 14 how IAC... is that why my car is idling weird? like it revs up and down when its idle.
Old Aug 29, 2007 | 09:25 PM
94allmotor's Avatar
how do i fix code 14?!?!?!
Old Aug 29, 2007 | 09:30 PM
Syndacate's Avatar
Default Re: (94allmotor)
Try replacing your IACV - and when you do - replace the IACV gasket, and make sure all the lines to it are tight.
EDIT:
IACV = Idle Air Control Valve
Old Aug 29, 2007 | 09:36 PM
smileycvc's Avatar
Default Re: (Syndacate)
First try tightening the valve on the backside. If that doesnt work then replace it.
Old Aug 30, 2007 | 08:46 PM
94allmotor's Avatar
i have no idea how to do any of this.. their 2 plugs near the throttle body that are unplug this is my first honda with a swap so this is all new to me.. i had 2 gsr's before but non had this problem
Old Aug 30, 2007 | 09:24 PM
smileycvc's Avatar
then plug them in if they are unplugged.
Old Aug 31, 2007 | 12:08 PM
94allmotor's Avatar
lets hope their something to even plug in.
Old Sep 2, 2007 | 10:55 AM
94allmotor's Avatar
any other reasons why i get code 14??
Old Sep 2, 2007 | 11:19 AM
serio_ENDLESS's Avatar
check the plug on the iacv sensor and see what color wires are there the two wires that supposed to hookup there is a blue w\black stripe and a yellow w\black stripe check this before you replace the sensor
Old Sep 2, 2007 | 11:40 AM
94allmotor's Avatar
i looked under the hood yes. the plug that plugs into the iacv was unplugged i didnt have time reset the ecu.. i couldnt find the fuse under the box under the hood i know where it is on integras..is it in a diff. spot in 00 civic
Old Sep 2, 2007 | 12:55 PM
HeikDiesel's Avatar
take the IAC out and clean the inside of it with brake clean, let it dry and put it back on. If that doesn't fix it let me know
Old Sep 2, 2007 | 12:57 PM
94allmotor's Avatar
thats the unit behind the intake manifold right with the rounds plug
Old Sep 2, 2007 | 12:59 PM
HeikDiesel's Avatar
on my h22 manifold its on the front but if your car is obd1 it should have a two wire round plug. On mine is 2 12mm head bolts that hold it on. Pull the sensor off and if it has two holes with o-rings that seal it you have the right sensor
Old Sep 2, 2007 | 01:00 PM
94allmotor's Avatar
i have a 00 civic with obd2 gsr swap
Old Sep 2, 2007 | 01:05 PM
HeikDiesel's Avatar
ok then im pretty sure its a 3 wire sensor. Let me see if i can find a pic of it
Old Sep 2, 2007 | 06:23 PM
94allmotor's Avatar
i also got a 3 wire plug that is unpluged..i have no wrk on wed. so ill check then
Old Sep 2, 2007 | 06:27 PM
HeikDiesel's Avatar
id say that might be the culprit
Old Sep 2, 2007 | 06:30 PM
pdiggitydogg's Avatar
iacv on b series is 2 wire
Your 3 wire...what are the colors of the wires?
iacv's are located on the intake manifold - theyre bolted directly to it, have an electrical connector and 2 coolant hoses
Old Sep 2, 2007 | 07:00 PM
HeikDiesel's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">iacv on b series is 2 wire
iacv's are located on the intake manifold - theyre bolted directly to it, have an electrical connector and 2 coolant hoses</TD></TR></TABLE>
You sure about that? I was reading that 98+ ITRs have a 3 wire IAC
Old Sep 2, 2007 | 07:17 PM
94allmotor's Avatar
yeah yes. i looked their was a round plug unplugged and i plugeed it back in..i got 00 civic with obd2 gsr swap i had 2 gsr's before this is my first with a swap its all new to me
Old Sep 2, 2007 | 08:25 PM
HeikDiesel's Avatar
so you plugged it back in and fixed it?
Old Sep 2, 2007 | 10:50 PM
THE OTHER 3 WIRE MAY BE THE CRANK SENSOR WHAT MOTOR DID YOUR 00 CIVIC HAVE WAS THE MANIFOLD LIKE I CARB OR REG. INTAKE CAUSE MOST 96-98 HAVE WIRES TO BE FIXED FOR THE IACV AND CRANK SENSOR
Old Sep 2, 2007 | 11:11 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (HeikDiesel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeikDiesel &raquo;</TD></TR><TR><TD CLASS="quote">
You sure about that? I was reading that 98+ ITRs have a 3 wire IAC</TD></TR></TABLE>
my 98spec jdm itr motor has a 2wire IACV plug
Old Sep 3, 2007 | 07:35 AM
94allmotor's Avatar
i dont think its the crank sensor...ill look into it my next day off is wed. ill look then
Old Sep 8, 2007 | 08:08 PM
94allmotor's Avatar
Default Re: (n1_egsex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex &raquo;</TD></TR><TR><TD CLASS="quote">
my 98spec jdm itr motor has a 2wire IACV plug</TD></TR></TABLE>
i got 2 wires also and i got gsr. still have no idea how to fix this problem
92GSR HB
Feb 17, 2010 08:29 AM
cr-x-91
Jun 10, 2007 12:50 AM
BoBo Racing
Dec 10, 2006 08:21 AM
trick_db
Aug 1, 2006 09:27 PM
GSRwBOOST
Oct 3, 2001 03:39 PM
