NEED HELP WITH N/A build
Old Aug 29, 2007 | 07:00 PM
97_dc2's Avatar
Default NEED HELP WITH N/A build
i was wondering which would be better for my gsr. ls crank/ls rods/pr3 pistons or just stick the pr3 pistons on my gsr rods? i have intake and header right now and just ordered an exhaust. input would be helpful
Old Aug 29, 2007 | 07:03 PM
95teg_ls's Avatar
Default Re: NEED HELP WITH N/A build (97_dc2)
gsr rods will be able to rev higher, unless you shot peed the ls rods or run forged ones.
Old Aug 29, 2007 | 09:05 PM
91redteg's Avatar
Default Re: NEED HELP WITH N/A build (95teg_ls)
keep yur gsr rods there made to rev higher. wuts appealing about the ls rods?
Old Aug 29, 2007 | 10:10 PM
GSR in progress 96's Avatar
* B A N N E D *
Im in the same boat and Im going with the LS crank/rods. Its like a LS/ Vtec but better.
Old Aug 29, 2007 | 10:11 PM
DC4 Dave's Avatar
I've honestly never understood what people were hoping to accomplish with swapping out the internals on a GS-R for LS parts.
Ideally, if you're looking for ~200whp that is, you can just freshen up the bottom end with ACL bearings, ARP hardware, and nicer pistons [whatever compression you want, I understand 11.5:1 is most common and effective on pump gas]. Then from there it's all head-work, as the valvetrain will be your weak spot.
Old Aug 29, 2007 | 10:15 PM
* B A N N E D *
Default Re: (DC4 Dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4 Dave &raquo;</TD></TR><TR><TD CLASS="quote">I've honestly never understood what people were hoping to accomplish with swapping out the internals on a GS-R for LS parts.</TD></TR></TABLE>
Trying to get all the torque you can. We all know its hard to find in a honda motor.
Old Aug 29, 2007 | 10:21 PM
DC4 Dave's Avatar
Default Re: (GSR in progress 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR in progress 96 &raquo;</TD></TR><TR><TD CLASS="quote">
Trying to get all the torque you can. We all know its hard to find in a honda motor.</TD></TR></TABLE>
So true. I'm biased though, my B20VTEC has loads of low-end power. Unfortunately the fun starts to die at 6800rpm, from stock Civic Si cams.
Old Aug 30, 2007 | 01:41 PM
97_dc2's Avatar
i was just wondering because my friends uncle put it in his gsr swapped da and it is pretty quick. what would the compression be if the type r pistons were put in with the gsr rods? would there be a big difference?
Old Aug 30, 2007 | 05:01 PM
SleeperGSR's Avatar
Ideally, if you're looking for ~200whp that is, you can just freshen up the bottom end with ACL bearings, ARP hardware, and nicer pistons [whatever compression you want, I understand 11.5:1 is most common and effective on pump gas]. Then from there it's all head-work, as the valvetrain will be your weak spot.</TD></TR></TABLE>
As i understand it you will be getting a longer stroke from an ls crank and rods. Although your suggestion did make alot of sence and is a good way to go.
Old Aug 30, 2007 | 05:25 PM
all-mtr-teg's Avatar
https://honda-tech.com/zerothread/1837872
some good info above
Old Aug 30, 2007 | 05:37 PM
grjp1988's Avatar
just buy an ls knifed crank and some ctr pistons hone your block get some head work and a good valvetrain and some pro1 cams should be a nice setup
carlossolorzano
Jul 11, 2011 08:32 PM
dirtyharryhatch
10
Jul 21, 2009 02:43 PM
Mfoehrkolb
Nov 21, 2007 05:37 PM
JUN-DA6
Aug 20, 2005 11:05 AM
SoOHiGH
May 29, 2005 10:15 PM
