msd problems..or is this normal
Old Jun 14, 2002 | 12:02 PM
loki2323's Avatar
Default msd problems..or is this normal
ok when I first installed my msd unit and the blaster coil...the car started up extremly fast...I was like whoa....it doesnt seem to do that anymore and I was wondering if there could be a problem with the unit or the coil? if there was would I have problems even starting the car? how could I check to see if everything is working the way it should
Old Jun 14, 2002 | 07:34 PM
InevitableRace's Avatar
Default Re: msd problems..or is this normal (loki2323)
first off what mods do you have and what kind of MSD is it?
Old Jun 14, 2002 | 08:44 PM
Mista Bone's Avatar
D Tranny Guru
check the plugs for electrode erroision.
MSD units eats plugs every 12-15k miles. I change mine once a year in the spring.
Old Jun 16, 2002 | 08:14 PM
loki2323's Avatar
Default Re: msd problems..or is this normal (Mista Bone)
changed the plugs and the car is running a lot better now..the white parts of the plugs look like they are burnt at the bottoms...car even starts better with the new plugs...any ideas why this happened???
mods: msd sci, msd blaster coil, msd cap, msd wires, 2.25 inch cat back exhaust, cai
Old Jun 17, 2002 | 03:33 AM
Mista Bone's Avatar
D Tranny Guru
MSD units with the more powerful spark thens to EAT plugs.
Old Jun 17, 2002 | 07:08 AM
88_SC_CRX_Si's Avatar
New User
The times I have glanced at the above mentioned, I never have seen what the voltage is, does anybody know???
OEM kicks out around 40,000 volts...
The times I have talked to peeps about up-grading mine (ignition, etc...) they told me to leave it stock. Unless, I was going to boost a high amount, or go with a high C/R...
[Modified by 88_SC_CRX_Si, 8:09 AM 6/17/2002]
lude98SH
Nov 3, 2005 08:15 PM
PowderB16
Nov 2, 2004 07:41 PM
gutted-dx
Aug 21, 2004 08:15 AM
Charlie Moua
Jul 7, 2002 11:39 AM
