DA half shaft and axles on a newere B-series swap?
I planned on using the axles and half shaft from a DA on my '00 Si transmission when I do my swap, HASport said I may need to change the seal on the half shaft side of the transmission.. Does anyone have any idea if this is true? as long as everything bolts up it should be okay, right?
da half shaft wont work.u will need dc integra half shaft.because i remember i bought da axles before, for my b16a swap and they wont fit cause they are male on both ends.
I'm using both DA axles and a half shaft.. so technically it should all work as long as it all bolts together, right?
it will work but i never really like the 90-93 half shaft. ifyou break a axle inside the shaft, its really hard to take it out
dustin
10
Apr 3, 2002 12:53 PM
