How Do I Replace Crankshaft Pulley on H22
I've spent about 2 hours searching for this now... How do I loosen the tensioner so I can remove the belts and take off the crankshaft pulley?
Thanks in advance for your help!
If you have the tranny off, it's easy, jam a socket extension into one of the holes through the Flywheel into the block casting. Them just find the longest pipe, hook it up to the crank pulley bolt and stand on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">you take a 14mm and loosen the bolt.</TD></TR></TABLE>
19 mm for Crank Pulley.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 »</TD></TR><TR><TD CLASS="quote">
thats not what he was asking.....but yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmbreed »</TD></TR><TR><TD CLASS="quote">first you will need my man muscles and i will rip it off with my arm if not then i will use my teeth
Yeah. Works everytime.
</TD></TR></TABLE>Yeah. Works everytime.
