High Flow cat
Old Aug 29, 2007 | 02:46 PM
JLefevers's Avatar
Default High Flow cat
ok i live in NC i need to get my car inspected saftey only. they failed it b/c it doesn't have a cat. if i buy the cheap ebay "high flow cat" is this gonna get me by so that i can pass inspection????
Old Aug 29, 2007 | 02:56 PM
jayturboef's Avatar
Default Re: High Flow cat (JLefevers)
get a magna flow..dont waste the time and money on that trash....but maby you only need it for a visual inspection ??????
Old Aug 29, 2007 | 03:02 PM
JLefevers's Avatar
Default Re: High Flow cat (jayturboef)
yeah i only need it for visual i plan on getting one just for now will it pass with one of these??
Old Aug 29, 2007 | 03:31 PM
JLefevers's Avatar
will i pass nc safety inspection using the cheap ebay "high flow cat"??
Old Aug 29, 2007 | 03:48 PM
jchrm80's Avatar
usually the ones off ebay that say they are high flow cats are just straight resonated pipes. believe me, I found out the hard way.
Old Aug 29, 2007 | 03:50 PM
JLefevers's Avatar
Default Re: (jchrm80)
yeah i know that is y i used the "" around it i am juss wanting to pass the safety/visual inspection i could care less if they produce power or rust easy this is juss for my dd and i juss want to pass
Old Aug 29, 2007 | 04:08 PM
jayturboef's Avatar
Default Re: (JLefevers)
that shuld be fine than..good luck
Old Aug 29, 2007 | 04:30 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (jayturboef)
If you just have to have a cat looking thing any will be a-ok.
If you need to meet a certin smog reg, then getting something carb like magnaflow or catco is worth the money.
Both will net the same power gain/loss of none.
Test pipes look just like a cat in your case Personally, since you won't lose anything might as well put something good on, because as hippy as it sounds we all share the earth. But even more so it doesn't smell like gas and cats cut a touch of noise.
Old Aug 29, 2007 | 04:32 PM
Ermil's Avatar
Default Re: (The Maxidermist)
Cat's are great for the earth! Think of the kids!
Littlegreend15
Mar 25, 2005 09:32 AM
88turdbucket
Jan 27, 2005 08:58 PM
EJ8 GSR-T
Nov 14, 2004 02:44 AM
CRXed
Apr 23, 2004 11:24 PM
Layziebtnh055
Apr 22, 2004 01:07 PM
