Do i need a fuel pressure regulator for when i put my injectors on to tune the car?
Old Aug 29, 2007 | 02:02 PM
sinister357's Avatar
Default forced induction question
i'm just wondering, when you have positive pressure in your manifold, what happens to those assesories that require vacumn such as the brake booster.
Old Aug 29, 2007 | 02:17 PM
Schister66's Avatar
Man U FTW
the brake booster has a check valve in it and shouldn't ever see boost. If you do not have a check valve, then the brake pedal becomes very hard to push....my buddy Zach found that out first hand when his anti-lag setup was finished on his FC....
Old Aug 29, 2007 | 02:23 PM
808jdm_profileEG6's Avatar
Default Do i need a fuel pressure regulator for when i put my injectors on to tune the car?
as stated.I just need to know whether or not I need a adjustable fuel pressure regulator for tuning the car with rc 750cc ...or could the 55psi pressure stay where it is at and just slow down the cycle of the injectors?
Old Aug 29, 2007 | 02:26 PM
Schister66's Avatar
Man U FTW
stock FPR will work just fine...i'm sure there is a point where it is necessary, but i'm in the low 300whp range and haven't ever used one...
Old Aug 29, 2007 | 03:13 PM
Default Re: (Schister66)
so without the vacumn helping the booster, the brake pedal would be very hard even with the check valve. is that right?
Old Aug 29, 2007 | 04:21 PM
Schister66's Avatar
Man U FTW
i can brake boost just fine and my brakes dont seem to die off too badly...i guess i really am not entirely sure on this answer, but i know what happens to me personally.....
Old Aug 29, 2007 | 04:50 PM
platinum00's Avatar
Default Re: Do i need a fuel pressure regulator for when i put my injectors on to tune the car? (808jdm_prof
Stock regulators are fine.
platinum.
Old Aug 29, 2007 | 04:56 PM
platinum00's Avatar
Default Re: forced induction question (sinister357)
It would be like breaking at WOT without boost. Check valve engages either way.
platinum
civic_driver
May 16, 2009 08:46 PM
turbobubble630
Jan 4, 2006 09:18 PM
B18EG6
Jan 29, 2003 09:55 PM
