How do you all mount FAL Windows
Old Aug 29, 2007 | 02:11 PM
integranator's Avatar
Default How do you all mount FAL Windows
Hey guys, I picked up a CF hatch, and I'm going to purchase the FAL rear windo kit for my drag/street integra.
How have you guys mounted your Windows? I'd prefer not to do the whole screw thing.
Old Aug 30, 2007 | 10:50 AM
A.E Motoring's Avatar
Default Re: How do you all mount FAL Windows (integranator)
rivets
Old Aug 30, 2007 | 11:04 AM
MrParks's Avatar
normal factory install with silicone
Old Aug 30, 2007 | 02:53 PM
h22 civic's Avatar
Default Re: How do you all mount FAL Windows (MrParks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrParks &raquo;</TD></TR><TR><TD CLASS="quote">normal factory install with silicone</TD></TR></TABLE>
Old Aug 30, 2007 | 03:27 PM
G2K's Avatar
G2K
Default Re: How do you all mount FAL Windows (h22 civic)
You can use Window Weld by 3M. Its designed to install factory glass, but works very well on lexan. Just make sure you don't get it all over the lexan, as there is no easy way to get it off.
Old Aug 30, 2007 | 05:38 PM
Kevin's Avatar
Default Re: How do you all mount FAL Windows (G2K)
When i mount our lexan windows, i use 3m black 5200 sealant (only because of the environment our boats are in, window weld would do the trick).
I like to fine line a border around the inside of the window before applying the sealant. Then apply a nice bead of sealant around the window using a metal roller to spread it around evenly. Finally i peel off the fine line tape before installing the window. The fine line gives it a nice edge and looks factory without having to use paint.
brian88
Apr 5, 2011 10:26 AM
sti grip
Aug 11, 2008 02:02 PM
NZDelsoldude
Sep 7, 2004 02:45 AM
one slow eg5
Aug 10, 2004 08:34 AM
275Performance
Feb 21, 2004 01:28 PM
